Full Range Speaker Photo Gallery
Old 8th May 2018, 01:31 PM   #3961
tuo is offline tuo  Finland
My Wolgast FAST system at a local DIY-speakers meeting. The full range is Visaton B-80 and the subwoofer Wavecor SW168WA01.
Click the image to open in full size.Click the image to open in full size.
Old 8th May 2018, 01:39 PM   #3962
soundbrigade is online now soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Nice stuff!!
But if I had known I'd be there.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 8th May 2018, 05:38 PM   #3963
Curlycat is offline Curlycat  South Africa
Philips 9710 Alnico in bass reflex cabs
Old 9th May 2018, 05:39 PM   #3964
friendly1uk is offline friendly1uk  United Kingdom
I decided to try my hand at routing, and leather work. I just wanted to use the router inside, but the 18mm board was 17.02 and the 18mm quarter round was 19mm. So I had to do the corners myself anyway. So my skills were quite stretched out here..
Even a bit of balsa wood in there, and I've not used that before either. So I'm happy enough. Just a cheap wrap as I'm not sure even oak would of taken to the r18 corners. Quite a bit more rubber crumb underlay went in, and various stuffing types weighed out.
Sound good, but I can still hear the box playing a part.
Old 10th May 2018, 03:35 PM   #3965
croat47 is offline croat47  United States
croat47's Avatar
@tuo...your paint/ply look is exactly what I am looking to do. Could you enlighten us as to your method? I am currently planning to build the painted portion, finish, and then glue the sides on. Is that your approach?
Aaron
Old 10th May 2018, 05:07 PM   #3966
Xerxes75 is offline Xerxes75  Netherlands
Do you have the plans for those cabinets?
R.
LM3886, LM4780, DCB1, DAC, First One v1.3, vintage drivers..
Old 27th May 2018, 11:57 PM   #3967
Wiggle8 is offline Wiggle8  Canada
Need to add a cap to the top but posting these early. Ported Alpair 10 tower, built for a local buyer. Still playing with the tuning a little but early impressions are positive.
Wood is Baltic birch plywood, edges are solid maple. Base is MDF painted black with some light speckled texture from a stone style paint. Finished with polyurethane.
Old 1st June 2018, 02:50 PM   #3968
dp1959 is offline dp1959  United Kingdom
My Alpair 12p's in a 20L bass reflex cabinet
Old 1st June 2018, 10:19 PM   #3969
jdrouin is offline jdrouin  United States
Woden Falcon for FF105WK, made of Lauan plywood. Finished with two coats of Danish oil. Thanks to Scott and the Planet 10 crew for such a great design!
Old 1st June 2018, 10:23 PM   #3970
Wiggle8: those are *gorgeous*!
dp1959: I love how you matched the enclosures to the room décor.
Full Range Speaker Photo GalleryHide this!Advertise here!
