Full Range Speaker Photo Gallery
Old 20th January 2018, 11:04 PM   #3901
sffrhd is offline sffrhd  United States
sffrhd's Avatar
Thanks for the kind words and amp suggestions. After free handing the first rebate, I thought, if I do more than one of these I oughta build a jig!
I'll have to look into those amps. Right now I'm working on a TDA7297 to replace the Lepai in my traveling rig. My brother thinks he wants a little Chi-Fi tube amp to pair with his uFonkens but I'll relay your suggestions.
Good to see another South Carolinian here, Poultrygeist!
Doug
Old 25th January 2018, 09:28 AM   #3902
wellenwanderer is offline wellenwanderer  Germany
Default Baffle with DY1026-U
Hello Fellows!
Here is a new project from me.
A baffle features the Rockwood DY1026-U and a tweeter from Visaton TW6NG. Sounds really good!
Pit
Old 25th January 2018, 11:57 PM   #3903
perkri is offline perkri  Canada
Very Nice!!!
I'm building the fe108e Sigma version of the same. How did you handle the damping on the inside?
P
Old 26th January 2018, 06:30 AM   #3904
Hello Perki!
In the Mark7 I put a layer Sonofil.
Important: The BR opening is to be kept free.
Good luck building the boxes.
Pit
Old 27th January 2018, 02:28 PM   #3905
Lebiu is offline Lebiu  Germany
Default My new PC-Speaker EITHNE
My new PC-speaker Eithne using a PEERLESS/VIFA TG9FD10-08 in 3 litres bassreflex
-3 dB @ 57 Hz
Click the image to open in full size. Click the image to open in full size.
Old 28th January 2018, 08:50 AM   #3906
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
Lebiu, looks great, impressive measurements. Have you also looked at distortion?
All atoms to the right!
Old 28th January 2018, 02:13 PM   #3907
vacuphile,
this speaker is designed for small listening levels, as they are typical on the desk. Distortions I measure only when I hear such at my usual listening volume.
Old 5th February 2018, 01:39 PM   #3908
Nenola is offline Nenola  Finland
Here's my current desktop speakers, Tangband W4-657SC in 5,5 liter reflex enclosure tuned to 65hz. Optimal box could be smaller and tuned higher, but I wanted to extend the low end response a bit. Made from 18mm MDF and painted with white rubber coat, nice and different finish but hard to keep clean cause dust sticks to it.
Source is PC -> nuforce DAC -> DIY TDA7375
Needed to document this because nearly the whole system is getting an update Full Range Speaker Photo Gallery
Old 10th February 2018, 11:56 AM   #3909
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
A few years ago I picked up what was left from a pair of TQWT speakers I have given to my oldest son. The nice Fostex TW15 tweeters were burned, propably due to amplifier clipping, and the bas/midrange - Fostex FE164 - were OK but the cones were slowly loosing from the chassis (bad glue?). I managed to glue the cones back and didn't want the drivers lying around and eventually selfdestruct, so I bought some boards of spruce, run som simple calculations using online software and came up with a pair of ... well ... .
Did just make the final installations (some kind of filling, cheap terminals and drivers) in order to use them tomorrow with my other speakers, when the HiFi-guys are coming.
Nothing fancy. Haven't even sanded them nor painted/tinted/oiled/waxed them, but they sound OK.
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 10th February 2018, 12:22 PM   #3910
zman01 is offline zman01  Bangladesh
Cool Magnus, good to see that you've revived the drivers and got them into a working cabinet.
Full Range Speaker Photo GalleryHide this!Advertise here!
