Full Range Speaker Photo Gallery
Old 17th November 2013, 09:03 PM   #2671
tilroh is offline tilroh  Australia
Originally Posted by zman01 View Post
Mack,
Nice MLTL you got there - the corners are done with real wood? What about the supra-baffle? How do they sound? The base for the SET amp also looks to be coming along nicely.
Yes, the front corners are done with solid Tasmanian Oak quarter round. Supra-baffle is Meranti, round-over or crown done with a 4" angle grinder with 60 grit. 12 coats of regular varnish top coated with Cabot's satin poly varnish from a spray can. I don't like shinny.
MDF has many coats of interior water based paint, sanded flat with 320 and waxed with floor wax.
It seems that I can play them louder without them sounding loud. Less bass than the BIBs. The "Sweet spot" is larger. Drivers had about 200 hours of break-in before install.
Cheers, Mack
Old 17th November 2013, 09:43 PM   #2672
mhouston is offline mhouston  Australia
mhouston's Avatar
Cheers, Mack
What efficiencies are the drivers? Any Xover?
Old 17th November 2013, 09:51 PM   #2673
FF 165 WK 92 dB
FE 166 En 94 dB
only a baffle step of 1.5mH Iron Core Inductor & 8Ω Resistor
Old 18th November 2013, 12:31 AM   #2674
mhouston's Avatar
FF 165 WK 92 dB
FE 166 En 94 dB
Did you like the sound more with BSC? Any of my SE tube amps (300B, 6EM7) would dive either speaker to good volume.
I hope you are using tube amps with these speakers.
Old 26th November 2013, 07:47 PM   #2675
ghpicard is offline ghpicard  Argentina
Beautiful builds. The time they took seems to be well spent. The environment is beautiful too. That wooden sculpture by the table seems very nice. Is that the usual listening place? They seem to be very far away from the walls.
Old 26th November 2013, 08:34 PM   #2676
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Hey Erik,
I'm going to move your posts over to the multiway thread.
planet10 needs your help:
Let's help Ruth and Dave
Old 30th November 2013, 07:28 PM   #2677
thetubeguy1954 is offline thetubeguy1954  United States
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Originally Posted by Overkill Audio View Post
Decided on Piano Black gloss as the finish.
Its hard to photograph as its a real mirror black, but I can assure you these things have presence in the room, now they are mounted on the wall...
The sound is everything I need.
Working some other versions for home cinema set up.
At the moment got 32 drivers for stereo... going to have close to 60 drivers in the home cinema rig!
Cheers
D.
Hi O.A.
First might I ask if you're the guy who built those awesome speakers with the Manger driver on top and I believe an 18" JBL below?
Your speakers sort of remind me of my friend Roger Russell's IDS-25 speakers which used 25 3.5" drivers per channel! But I digress, I hope you'll be telling us a little bit more about your speakers, hummm? While I find the idea of having 32 drivers for stereo ---{I'm assuming you mean 16 drivers per channel}--- the type of driver itself would be quite critical in how the end product sounds, no? So how about sharing which drivers you're using? Inquiring minds want to know!
Thanks!
Thetubeguy1954
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society--Full-range/Wide-range Drivers--High Sensitivity Speakers--Front & Back-Loaded Horns.
Old 8th December 2013, 07:38 PM   #2678
larryldspkr is offline larryldspkr  Canada
larryldspkr's Avatar
Default Fullrange pics
Recently completed project, Alpair 10.2 tapered folded MLTL.
Larry
Old 8th December 2013, 07:41 PM   #2679
RK1 is offline RK1
very nice (pity that the speakers are not embedded deeper)
Old 8th December 2013, 07:52 PM   #2680
RK1, the grill is heavily bevelled inside and out and sits on top of the driver frame. It acts like a short waveguide.
Larry
Full Range Speaker Photo GalleryHide this!Advertise here!
