Full Range Speaker Photo Gallery
Old 26th April 2013, 02:14 PM   #2401
DYNABLASTERTUNERS is offline DYNABLASTERTUNERS  Serbia
DYNABLASTERTUNERS's Avatar
Yes all of those are in good shape- surroundings are soft!
Those six 8" with sand on the cone will all be used in DUNE system, 4 of them just to play bass in about 100L each as spice harvesters, so no matter that dustcap is damaged- au contraire, they have survived Shai Hulud attack
some of my Designs www.dynablaster.deviantart.com/gallery
Old 26th April 2013, 02:46 PM   #2402
arjank is offline arjank  Netherlands
You're a DUNE fanatic, how cool.
These spice harvesters will perform well on Geidi Prime
Old 26th April 2013, 02:54 PM   #2403
bonzo15011978 is offline bonzo15011978  Italy
Originally Posted by simenms View Post
Hi Simenms, pay attention to the acoustic feedback!
Your TT must be placed not too close to the speakers, and not between them in any case.
The TT must be placed on a shelf or on a proper support, take a look here:
The TNT SandBlaster 1.0
Anyway: your speakers are a work of art! Lots of compliments!
Old 1st May 2013, 05:19 AM   #2404
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
I invented these for my child, with left-overs...turned out to be too big so I kept them for myself.
I am lazy to finish them: increase the bass horn. The idea is to make a nice cabinet for a 6" or 8" Audio Nirvana. Sound really good and image very, very well for a USD30 surround speaker...
I hate square boxes, really.
"Cascode all thy outputs".
Old 5th May 2013, 03:04 PM   #2405
jhutka is offline jhutka  United States
jhutka's Avatar
Default Folded TABAQs with TangBand W3-881SI
Oak plywood
Polyurethane only on side panels
Truck Bed Liner Paint on the black parts. (thanks Bob B.!)
Old 5th May 2013, 06:20 PM   #2406
toobhed is offline toobhed  United States
Nice folded TABAQs, Jhutka! I built a pair sometime ago with a different TB, but I have another pair the same as yours.....I'll have to build another.....
Old 5th May 2013, 08:44 PM   #2407
TerryO is offline TerryO  United States
TerryO's Avatar
Hi Max,
Could you comment on the particulars of this design? Very interesting!
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 6th May 2013, 12:54 PM   #2408
maxlorenz's Avatar
Originally Posted by TerryO View Post
Hi Max,
Best Regards,
TerryO
Thnak you dear, for your interest.
This idea was inspired by my snobish little brother who loves expensive bookshelf speakers which image well, have a lot of midrange and HF information but lack true bass. I commented him that a real man would make a hole at the back of the enclosure a add a very big folded horn to profit from some LF
I had these AIWA surrounds doing nothing (5"?) and on a previous life I had build that 3 column pedestal with heavy duty PVC: it is supposed to be a HF diffractor plus bass trap but I cannot remember the name of the original...well I made a hole and the back of the enclosure, as I am a real man and adapted a connection to the central tube, through which the sound wave ascends. The central tube is connected with both lateral tubes at the upper end, which doubles diameter, and then the sound wave descends and is transmited to the wood horn. I decided to use the floor as the "floor" of the horn to win time but now I have to complete and expand the mouth. I would say that the lowest usable LF (Fo?) is around 80Hz now. The advantage I predicted is present. For example, Bach's cello suites sound wonderfully articulated with rich bass harmonics.
As a bet, the central tube has also a hole at the horn end (which can be blocked at will).
I use them with bass reinforced with woofers at present, with active CX at 100Hz.
I can draw a diagram if you so wish, of the present speaker and of the following logical step in design I plan...a tip: a too big bass horn does not exist...always build big.
I hope you like it.
M.
Old 6th May 2013, 05:05 PM   #2409
DIYNick is offline DIYNick  United Kingdom
I'm quite pleased with myself after spot of DIY so I thought I would share with you all. A full ranger and stand (which was the hardest thing I've ever built myself).
Old 6th May 2013, 06:20 PM   #2410
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
Those look incredible DIYNick. What driver is that? How do they sound.
Full Range Speaker Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
