Full Range Speaker Photo Gallery
Old 11th March 2013, 06:22 AM   #2341
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Originally Posted by Philfr View Post
and adding a variable BSC.
Very nice work. Is the variable part a variable resistor or something more complex?
My understanding is that a BSC is easiest approximated using a parallel combination of a resistor and inductor which is in series with the driver.
Increasing the resistor increases the ammount of BSC loss and the inductor controls the tunover frequency.
...still looking for the holy grail.
Old 11th March 2013, 08:06 AM   #2342
Philfr is offline Philfr  France
Hi navin,
You are right about BSC network.
I only use a variable resistor and a coil. In this case I add a cap (1,8 uF) in parallel with BSC to increase high frequencies level.
So I can adjust midrange according room, amp or music.
Phil.
Old 11th March 2013, 09:02 AM   #2343
mhouston is offline mhouston  Australia
mhouston's Avatar
Hi navin,
Phil.
Would you put up a the schematic with values of your BSC. I have used BSCs with my Fostex speakers.
Old 11th March 2013, 09:10 AM   #2344
Schematic and calculate :
Loudspeaker Diffraction Loss and Baffle Step Compensation Circuits
In my case I have 2 mH and near 6,8 Ohms..
What is your design and drivers ?
Phil.
Old 11th March 2013, 09:47 AM   #2345
mhouston's Avatar
Hi navin,
Phil.
I may try adding the cap.
Old 11th March 2013, 09:55 AM   #2346
Have a look at my little experience with FE207E in MLTL (sorry in french) :
BSC ou correction de taille
Old 11th March 2013, 11:37 AM   #2347
mhouston's Avatar
I'll assume you put the cap across the inductor and the best cap for you was 2.2uf?
Old 11th March 2013, 11:44 AM   #2348
cap is in parallel with BSC like a notch filter..
Old 13th March 2013, 02:10 AM   #2349
cross reference is offline cross reference  United States
Here's my trapezoid boxes for the FE-126en drivers ( Blue boxes) and the FF-125wk drivers in the (Black boxes). This box design is still a work in progress after a year and will be in-till I get it right . Jeff
Old 13th March 2013, 03:27 AM   #2350
Carlp is offline Carlp  United States
Interesting and nice looking, Jeff. But...what are they? Reflex? Ported? TL? Etc. etc.
Full Range Speaker Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
