Full Range Speaker Photo Gallery
Old 18th May 2012, 11:26 PM   #2101
ansepe74 is offline ansepe74  Norway
Send a message via MSN to ansepe74 Send a message via Yahoo to ansepe74
Looks great!
What element?
Tubes, horns & DIY..
Old 19th May 2012, 03:21 AM   #2102
Carlp is offline Carlp  United States
Looks an awful lot like a commercial Tang Band speaker design I've seen (Tang Band D4-1 DIY Back Horn Speaker Kit). Is this really DIY?
Old 19th May 2012, 10:27 PM   #2103
Godzilla is offline Godzilla  United States
Godzilla's Avatar
How do those Diatones sound to you?
Old 1st June 2012, 01:47 PM   #2104
IG81 is offline IG81  Canada
IG81's Avatar
Here's some small folded TL's I quickly put together to have something for Netflix and YouTube on the bedroom PC. Driver is the 4.5" Pioneer A11. The box has a 2 liters coupling chamber and a ~30" line about 4 liters in volume. It's damped on the initial 2/3 with polyfill quilt batting. Finish is gloss black Tremclad and a cork sheet in front.
Response, with mic ~8" away from the cone and pipe output, speaker on a stand and "baffled" with a 20"x30" foam-core sheet to minimize front-back interference a bit.
They do well enough for their intended purpose, the aim was compact. The variable loudness control on the Denon receiver that drives them makes for a decent ersatz-BSC. They are playing roughly in quarter-space though, especially if seated in front and nearfield, so they don't need much of it.
IG
Old 1st June 2012, 03:40 PM   #2105
TerryO is offline TerryO  United States
TerryO's Avatar
IG,
Again you've done a great job. A "little" different from your Karlson's, but very nice all the same!
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 1st June 2012, 03:59 PM   #2106
IG81's Avatar
Originally Posted by TerryO View Post
IG,
Best Regards,
TerryO
Thanks! Seems like I go for real big or real small, to my scale at least. Though I am cooking up something on the large side of things, to be built in coming months hopefully.
IG
Old 1st June 2012, 05:27 PM   #2107
KyleinCowichan is offline KyleinCowichan  Canada
KyleinCowichan's Avatar
Looks nice IG! Any chance of seeing what the internals of the enclosure look like?
Kyle
Old 1st June 2012, 05:31 PM   #2108
chrisb is offline chrisb
Kyle
posted elsewhere:
As Jeff noted, really more of an aperiodic than a critically damped TL - but should still work just fine
kinda burnt out - taking a break
Old 1st June 2012, 05:32 PM   #2109
Ah, thanks Chris! Very cool.
Kyle
Old 1st June 2012, 06:14 PM   #2110
IG81's Avatar
Originally Posted by chrisb View Post
posted elsewhere:
That was a test setup and the final iteration has the first two thirds of the line damped with poly-fill batting, that is to say, the last vetical section was left empty. The coupling chamber is only lined with some thick felt, something called "Maxolite".
I've yet to check the impedance profile for this little speaker, but IMO it will be close to a single peak, much like a closed/aperiodic box. Sticking my ear close to the pipe exit, there is more to be heard than a true aperiodic box though. I stuck enough polyfill to kill some upper-band ripples along with two deep notches.
IG
Full Range Speaker Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
