Full Range Speaker Photo Gallery
Old 7th July 2011, 10:01 AM   #1601
superlian is offline superlian  Norway
@malibujeff
Exellent veneering. Could you please tell how you made it?
Old 7th July 2011, 01:33 PM   #1602
malibujeff is offline malibujeff  United States
malibujeff's Avatar
Originally Posted by superlian View Post
@malibujeff
Thanks Superlian. I used the iron on method for the veneer. It worked great. First I softened the veneer with some Super-Soft 2 Veneer Softener.
You can see my build pictures HERE
Old 9th July 2011, 08:40 PM   #1603
Charcoal is offline Charcoal  Ukraine
sonido sfr200 in blh
Old 9th July 2011, 09:12 PM   #1604
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
Charcoal: You've actually built the Aion!!!???? RESPECT, man!
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 10th July 2011, 06:38 PM   #1605
thetubeguy1954 is offline thetubeguy1954  United States
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
How's the frequency response of the Aion? Also how low do they go, 30Hz, 40Hz?
Thetubeguy1954 (Tom Scata)
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society--Full-range/Wide-range Drivers--High Sensitivity Speakers--Front & Back-Loaded Horns.
Old 11th July 2011, 01:13 PM   #1606
thats smaller version of AION, we cal it in Ukraine: sandwatch
AION I built previously. If close to the wall - 45Hw was at 3db in my room. I build also various labirynth speakers with sonido, hobby like a business.
Old 12th July 2011, 04:48 AM   #1607
xpheolix is offline xpheolix  United States
xpheolix's Avatar
These are my mMar-Kel70 milliSize (p10 hifi | Box Library / CSS) speakers that I just finished earlier today. Recycled bamboo flooring biscuit-jointed to create solid boards, milled to 5/8" with a solid dark mahogany baffle. I used the 85% denim lining from CSS as well as some of their input terminals. The drivers are the CSS EL70s. What would some suggestions be for an amp to run these guys? Although I don't have thousands to spend, the knowledge of the better amps out there is also good to have so all suggestions welcome.
Old 12th July 2011, 06:48 AM   #1608
toobhed is offline toobhed  United States
Kismit! I just completed a P-10 flatpac build of the very same speakers and finished installing the drivers this afternoon....yours are gorgeous...congratulations! This is my second build...I used a cherry stain and polyurethane laquer finish on the flatpac's 1/2" birch plywood. One object lesson learned is that darker stain is less forgiving than natural stain on cabinet seam glue-traces.
The EL-70s I installed went through a few weeks of break-in and so far I've auditioned the finished products with 2 amps: First Watt J2 and LadyDay 300B monoblocks. While I prefer the J2 with Markaudio metal drivers like A10.2 and CHR-70, the EL-70s, like my paper Fostex drivers, seem to go better with the 300bs... I'll try other tube vs. silicone amps to see if the speaker's aparent tube preference holds. I'm very impressed with the bass, lack of shout and overall musicallity of the mMar-Kel70's and would encourage you to try some relatively low-wattage EL-84s or SET 300Bs tube amps.
Mario
Old 12th July 2011, 07:51 AM   #1609
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
15mm Baltic Birch.
Nice millis guys
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th July 2011, 12:00 PM   #1610
300 SWR sonido in 170l BR "NAGA" and 12L BR with 145 SWR Sonido.
Full Range Speaker Photo GalleryHide this!Advertise here!
