Full Range Speaker Photo Gallery
Old 20th April 2010, 06:23 PM   #1171
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
is that a challenge?
No. Just paraphrasing the comment you made about how much you "disliked" the finish -- and the work to do it -- on ours.
I know that at some point you'll likey swoop them away noe that we have confirmed they work.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th April 2010, 06:40 PM   #1172
head1962 is offline head1962  Switzerland
Originally Posted by gps View Post
BVR / vintage Philips AD7061/M4 ( phase plug + magnet ring compensation )
Hello GPS!
these look real nice!!
I have some phillips and Isophone all-range gathering dust.
can you post the plans?
I sure would like to try them in your enclosure.
Gerrit
Old 20th April 2010, 10:01 PM   #1173
fishski13 is offline fishski13  United States
Originally Posted by zayne742 View Post
Those are very nice, and I see you have caught a picture of the elusive Dust Cap Monster!
Old 20th April 2010, 10:15 PM   #1174
just madness, no particular thought process . that's part of the reason i ran the wires directly out - i want to be able to try both parallel and series. i have a Tripath based 30W Amp4 upstairs and an %80 completed F5. i'll end up with 16ohm connection with these amps and the SE tube amp i have on deck.
Originally Posted by thetubeguy1954 View Post
Hello Fishski13!
Please forgive the ignorance of a technically inept amongst us, but why would you have chosen to wire them in parallel for a measured impedance of 3.5 ohms over wiring in series for a higher impedance? Just curious what the thought process behind that decision was...
Tom Scata (thetubeguy1954)
"The man that hath no music in himself nor is not moved with concord of sweet sounds is fit for treasons, stratagems and spoils."
- William Shakespeare
Old 20th April 2010, 11:43 PM   #1175
thetubeguy1954 is offline thetubeguy1954  United States
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Hello Fishski13!
Thanks for the clarification...
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society--Full-range/Wide-range Drivers--High Sensitivity Speakers--Front & Back-Loaded Horns.
Old 21st April 2010, 12:16 AM   #1176
DonB is offline DonB  United States
DonB's Avatar
Yes, very nice work indeed. I've seen your video's on YouTube and you mention that the horns were sourced from Rainer Flock. When I use the link on your page (http://www.flo-horns.de) is shows the URL is no longer working or valid. Can you give me an alternative way to contact Rainer? I thank you in advance for your time
Originally Posted by sarrisk View Post
Upgrading my BLH using the BMS 4524 driver
Old 21st April 2010, 03:30 PM   #1177
gps is offline gps  Bulgaria
Originally Posted by planet10 View Post
Those are lovely... i just pulled a set of those drivers, i'd be interested in more detail.
dave
Hi Dave,
I think project like Iris 1v1 is better for Philips AD7061/M4... but small room + high cabinets + Wife Factor = isn’t a good idea . My BVR with one mouth horn is compromise.
Different vintage Philips AD7061/M4 have different T/S parameters , Fs from 68Hz to 87Hz, Qts from 0,65 to 0,9. My drivers used to have Fs=74Hz/Qts=0,68 . After the modification (new spider) Fs came down to 68Hz , with magnet ring Qts came down to 0,48. With these parameters I calculated horn lenght=90cm, horn throat=60cm² , horn mouth=700cm², CC=9L.
I`m not sure if philips drivers will sound good without modification in my project.
Philips with magnet ring and my prevous 2 way BVR project (first steps )in process of development
Old 21st April 2010, 05:42 PM   #1178
frugal-phile(tm)
planet10's Avatar
Thanx. How did you replace the spider?
dave
Old 21st April 2010, 07:13 PM   #1179
chrisb is offline chrisb
dave
probably faster to build and veneer another pair than fix that hammer-coat paint finish
I bet they'd burn some pretty colors
like my mind, this space intentionally blank
Old 21st April 2010, 09:13 PM   #1180
frugal-phile(tm)
planet10's Avatar
Sounds like they are staying hammerkoat grey then ... that's OK, i've just started some complementary colour drivers for them (freeing up the drivers in them for the woofer#6 blade-like boxes (you are gonna hate me when you see the sat drawing), and the MJK/Shearer OBs)
dave
Full Range Speaker Photo GalleryHide this!Advertise here!
