Full Range Speaker Photo Gallery
Here some pictures of my other small 5.0 HT system based on the Tangband W3-871s units.
(Lancetta HE in Cyburgh's Needle outfit and 2x CT209 / 1x CT209AL)
All filters applied are the same as the Lancetta High-End version.
All cabinets are increased in outher size for cosmetic resons.
The cabinets are made of 10mm thick MDF, finished with silver paint all arround.
The Needle's have a compartment at the bottom filled with the filter and sand.
Landroval said:
Why the W3-315SC for the center? To me it sounds clearly different than a W3-817S.
@ Landroval :
The W3-315SC sounds just a little bit different in the middle/high freq.
after an experiment with different units for the centre I found out
that in this configuration the W3-315SC sounds more open and
detailed .
Placed in the Needle the W3-315SC didn't sound that great, to
much, little agressive in the middle.
But for voices, comming over the centre unit it sounds quite perfect.
to Planet 10:
I listened to Tom Z's horn at Bob's the other day. I found them excellent in the upper range and they had fantastic lower bass. Amazing for that size of a speaker. After listening for a while, we did stuff the horn with some poly stuffing to eliminate the mid-bass honking. I wonder if you found the same problem? I also had to deal with the same problem with my Jordan transmission lines and also had to use stuffing in the vent to remove some of the mid-bass honking.
/Joe
Where did you put the polyfluff... the honk in the mids was the most objectionable issue (i still haven't heard the 2nd pair yet)
dave
Hi there.
I did Nagaoka D58-ES for front speakers and D37 for back speakers using FE208EZ + FT96H and FE168EZ :
http://satriany.free.fr/pages/enceintes/index.php
Greg.
Thanks but I did not spend some time to translate almost all my site in english to get that kind of comment 😉 Just click the english flag 😀
You can find some picture of the assembling there too.
I used Mr Nagaoka plans that you can find on some japanese sites or in his books available at Madisound.
The finish is two layer of Vernish, mahogany tree colour. I find this colour quite warm and beautiful, suits with my appartement.
Greg.
I like more the D58 because they have deeper bass response and the FT96H is doing a good job. On the D37 I am only using a FE168EZ without a tweeter but I should put one to get clearer and better highest frequencies.
I am also powering the D58 with a Naim NAIT which is quite an excellent amp and only a T-amp for the D37.
But for a true full-range speaker, the D37 is quite amazing, you just enjoy the music.
I hope I answered you question, feel free to ask anything.
GreG.
Re: front view
doggy said:
Had these 16 ohm monarch 3-1/2",alnico,steel frame round holes in basket.... 12" wide X 30-1/2" high X6-1/4" deep; inside baffles are 4-3/16" wide....They don't go down to far but a very enjoyable and cohesive sound. ...
how low do they go. they look beautiful to me esp for such a small cabinet. maybe the 108 sigma's might offer an upgraded sound.
Hi guys,
Here is a quick pic of the Zigmahornets (with FE103E drivers) I recently put together.
Originally they were going to be light coloured so I put a maple veneer on them. We then decided to go with a mid tone so I applied a teak stain. Maple does not take stain well! Took much exta work to make them look good... The cabnets are made from 5/8" MDF. I routed a curve on the front two edges so I could wrap one piece of veneer around the front and sides. Plus it gives a nice smooth look...
Anyways this was the first time I had even done anything like this and enjoyed it very much. I discovered I really enjoy woodwork and have since bought a bunch of tools to help (mostly one tool - a Shopsmith).
I picked the Zigmahornet design since I figured it would look good with our new TV. They sound great as well, so now I am thinking of building new speakers for the theatre room! (Although a hushbox for my projector would be the best increase per dollar in sound performance 🙂)
Maybe some Voigt Pipes for the theatre... I have a 14' ceiling in there so I can make some huge ones!!!
Thanks, James
Here is a picture of my speakers for front channels.
The bigger ones are my new fullrange speakers for stereo listening,Jordan jx92s in GM:s great mltl 48".The enclosures are my own design.
(the smaller 3 way speakers are for movies)
