Full Range Speaker Photo Gallery - Page 168 - diyAudio
Old 23rd August 2011, 03:24 PM   #1671
gychang is offline gychang  United States
Originally Posted by nuconz View Post
thanks.
how did it sound with vent sealed?
there was a tiny vent, overall did not sound quite right in lower bass...
Good sound from Davis, CA
Old 23rd August 2011, 04:02 PM   #1672
chuyler1's Avatar
My Alpair Pensil 10.2 i just finished...
Click the image to open in full size.Click the image to open in full size.
Old 23rd August 2011, 04:07 PM   #1673
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
Wow, beautiful!
Old 23rd August 2011, 04:27 PM   #1674
chuyler1's Avatar
They are 3/4" birch ply from Home depot. the front face has birch veneer to hide the plywood edges but the rest of the joints were mitred so I could simply stain the plywood.
* Used 220 grit with an orbital sander on all surfaces
* Applied 2 coats of Watco Danish Oil (Dark Walnut). Coated with a foam brush, wiped off after 15 minutes with a rag.
* applied 2 coats of Minwax Wipe-on poly. Coated with a rag
* applied 1 coat of Minwax Finishing wax
* Buffed out to a semi-gloss finish using an automotive buffer
A step I skipped, was the pre-stain.
Without it, you get some blotches, but the wood takes the color a lot better...and i find the blotches add character.
Old 23rd August 2011, 07:22 PM   #1675
soundbrigade's Avatar
Send a message via MSN to soundbrigade
chuyler1: What kind of drivers?
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 23rd August 2011, 07:26 PM   #1676
chuyler1's Avatar
They are Mark Audio Alpair 10.2. Plans for the enclosure are here: http://homepage.mac.com/tlinespeaker...ete-100711.pdf
Old 23rd August 2011, 07:30 PM   #1677
zman01 is offline zman01  Bangladesh
Nice work Chuyler1, speakers look really beautiful. How do you like the sound?
Old 23rd August 2011, 07:57 PM   #1678
chuyler1's Avatar
Immediately, I like them better than my Frugelhorn MK1s. Tons more bass. However there are things the FH1s do a little better. I don't have enough hours on the Pensils to be too critical just yet though. I keep adding stuffing because there is so much bass.
Old 23rd August 2011, 09:20 PM   #1679
vinylkid58's Avatar
Try pulling them out of the corners and in towards the center a bit more. Nice work BTW.
jeff
Old 23rd August 2011, 09:32 PM   #1680
chuyler1's Avatar
yeah, that works...except the wife wants them further back.
Copyright 1999-2017 diyAudio
