Full Range Speaker Photo Gallery - Page 139 - diyAudio
Old 11th January 2011, 11:33 PM   #1381
hebrer is offline hebrer  Slovakia
Default Follow-up
Actually, as a follow-up to previous message and opinion possibly relevant to others: the SET amp using EL-84 may not be the best candidate to achieve synergy with Fostex FE127eN because its power may not be enough to handle speakers with 91dB sensitivity (that is before enabling process, which increases the sound quality but decreases the sensitivity).
I am currently building my second pair of full-range speakers to achieve higher sensitivity and (hopefully) better match with the amp. The second speaker project is not finished and therefore not yet a good candidate for this thread (it uses 10" cast frame fullrange drivers in back-loaded horn arrangement; sensitivity of the driver: 95 dB).
Old 12th January 2011, 10:09 PM   #1382
chrisb is offline chrisb  Canada
Well here we go again discussing the "suitability" of amps / speaker sensitivity / individual listener preference issue - I guess the parsing of the preceding gives a hint as to my take on it.
FWIW, I've built and listened to many dozens of enclosures with FE 127E in mono and bi-pole configurations and one of the sweeter sounding amps I've heard them with is a variation on Alex Kitic's RH84 design. (my scribbled schematic attached) This particular project arouse from some dabbling around with spare parts after performing some simple mods to a pair of Zen C and building a matching Bottlehead ForeplayII a few years back - and had approx the same power as the Zen. To my taste, I preferred the triode connected EF86 as driver to a variety of 6922/6N1P/ 6DJ8 etc types that I sampled at the time - the only downside is that it's not a dual section device.
Slightly higher on my preferred amp list for the FE127 is a custom EL34 SET designed by Eddie Vaughn - GZ34/film cap & choke filtered power supply, Raytheon 5842 driver, Bud Purvine OPT. More power than the Carina that a friend of mine had - also a very sweet amp, but quite frankly between the 2, I preferred the EL34.
From the DHTs in my collection, I prefer the Bottlehead Paramour 2A3 (3.?? watts) to the George Wright Mono7 300B for driving the FE127E.
As to any miniscule loss of sensitivity resulting from the EnABL process, I find that the extra depth of information it unmasks more than makes amends for that. As very little of my musical listening is over SPL of 90dB, I can happily enjoy the match of 2 or 3 "tube" watts and 91/92 sensitivity drivers - certainly more so than 20-30watts of SS - including T-amps and a DIY mini-Aleph. If that means my taste is on the "romantic" side - so be it.
... so, not as easy at it sounds, this letting go thing
Old 13th January 2011, 11:37 AM   #1383
felixx is offline felixx  Romania
felixx's Avatar
Visaton 6,5" into closed 9,3 litre enclosure.
These "things" is intendet to work into a medium environment.Soon will be available for sale.
System Pictures & Description
"I'm glad I can build my own mistakes."
https://picasaweb.google.com/115586837612433686520
Old 15th January 2011, 02:44 PM   #1384
DIYNick is offline DIYNick  United Kingdom
Default My contribution
I thought it was about time I posted my contribution to the Full Range picture thread after being inspired by what other people had done. (mind you most of you know what you are doing....I don't)
Mass Loaded Transmission Line (2.2m long TL) approx 20 litres volume, drivers are CSS 125's.
Hope you like
Old 15th January 2011, 02:47 PM   #1385
Tripmaster's Avatar
Very nice Nick
Old 15th January 2011, 06:03 PM   #1386
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Those are beautiful. Looks like you know what you're doing to me!
PASSIONN
Old 15th January 2011, 07:06 PM   #1387
Very kind of you, but I assure you were the actual proper speaker design is concerned I do not! I can however make them look ok
Nick
Old 15th January 2011, 07:08 PM   #1388
brsanko's Avatar
Ah, I see, well then the pertanent question would be: how do they sound?
PASSIONN
Old 15th January 2011, 07:10 PM   #1389
brsanko's Avatar
Those look like very interesting drivers where do I find more information on them?
PASSIONN
Old 15th January 2011, 07:14 PM   #1390
Well, initially they were a bit bright and base light which I was surprised about given the TL. However through a comination of running in and adding quite a Bit of stuffing behind the driver and down the start of the TL. I soon got a better balance. Firing them straight ahead also helps. After a week of continous use and playing around with wool/foam I'm quite happy with them now. If you wanted proper bass power a sub would be needed, but this could be to do with the power amp which is a bit bass light (tripath 2020 amp).
Driver link below
http://diyaudioprojects.com/Drivers/CSS-FR125SR/
Nick
Copyright 1999-2017 diyAudio
