Old 24th June 2010, 06:08 PM   #1251
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
Originally Posted by vitalstates View Post
Alpair 10 nearfield - standard BR from winisd - tuned to 49hz as default but bass needs serious taming.......
Excellent build! The 10 seems to have the smoothest response of the Alpairs, how do you find it? Is the treble as extended as the plot suggests? Looks like quite a special driver
Old 24th June 2010, 06:24 PM   #1252
frugal-phile(tm)
planet10's Avatar
Your woodwoork is lovely. We have the same issue facing us with the bass on the MJK horn for the A10. The primeSize miniOnken for the A10 has good bass.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th June 2010, 08:19 PM   #1253
vitalstates's Avatar
dave
Awww, you say the nicest things.....
it was a straight winisd thing....BR is not really my thing but I needed some nearfields for the studio........the predecessors were mackie 824s and tannoy reveals so they've got their work cut out if they want to avoid the skip(dumpster)......
its 10ltrs with 47x177 port and with the port open they are frightening(bad). With the port stuffed they are the equal of their predecessors(so far) but I will start measuring in earnest tomorrow.
Ed
There is nowhere you can be that isn't where you're meant to be
www.vitalstates.org
Old 24th June 2010, 08:30 PM   #1254
frugal-phile(tm)
planet10's Avatar
10 litres is a bit small... i settled on 13 litre (and then my hiR ports -- if i use a piece of PVC pipe i inevitibly end up putting a "sock" in the port. Sounds like soe judicial use of carefully cut open cel foam is required.
dave
Old 24th June 2010, 08:46 PM   #1255
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
Those look nice.
Interesting use of the blue packing foam...
dave
Dave,
Where would I look for some of that blue foam packing material?
Thetubeguy1954 (Tom Scata)
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
Old 24th June 2010, 09:00 PM   #1256
frugal-phile(tm)
planet10's Avatar
I get it from the Apple Service boxes that i am reponsible for recycling. I usually use the waffle stuff for packing. There is some denser stuff in the same boxes that makes for good aperiodic port material.
dave
Old 24th June 2010, 09:26 PM   #1257
vinylkid58's Avatar
That's odd, as the fr plot in WinISD looks pretty good for that tuning.
Jeff
Old 24th June 2010, 09:38 PM   #1258
dave
Ok, I should have been clearer. How can I obtain some for myself? In other words do you know where I can buy some?
Thanks...
Old 24th June 2010, 09:54 PM   #1259
frugal-phile(tm)
planet10's Avatar
Try a packing company. Or go to you local Apple service and ask if you can get, and recycle any spare service parts boxes.
dave
Old 25th June 2010, 04:39 PM   #1260
speakrsrfun's Avatar
Ed
Box is a tad small but try stuffing the ports with drinking straws cut to the same length of the port, This should add a bit more resistance and still keep the tuning. I've found little changes with the upper bass in this fix yet the lower registers seem to be much more controlled....
What was that?... I can't hear you I have a line array filling my ears.
Copyright ©1999-2013 diyAudio
