Full Range Speaker Photo Gallery - Page 120 - diyAudio
Old 3rd May 2010, 02:54 AM   #1191
doorman is offline doorman  Canada
doorman's Avatar
Nice work, Torrence!
It's a very clean look!
Don
Old 5th May 2010, 11:05 AM   #1192
Jamii is offline Jamii  Australia
Finally started work on my Curvy Changs, thanks frugal horn for the plans! Managed to get this all out of one 2.4x1.4 sheet..... and then ran out of wood. I'm making these as a project with my old man, he's a craftsman and builds (beautiful) boats so im hoping ill learn those all important skills! I'm only 23, could be a dangerous thing getting into higher-end audio at such a young age haha...
they are not as pretty as some of your cabinets, and are just a work in progress, but here you go! Finnish will be semi-gloss black. will post more as work progresses.
James
Old 6th May 2010, 05:37 PM   #1193
chrisb is offline chrisb  Canada
Originally Posted by Jamii View Post
Finally started work on my Curvy Changs...
Jamii:
still get much kidding about the street address number?
Yes, you're young enough that this could become an addictive hobby, so it might not be out of place to suggest that for any future speaker projects you consider using quality grade multi-layer plywood.
As far as I'm concerned it sounds superior to MDF or particle board, and by the time you account for the time, equipment and materials required for a high quality black paint finish on MDF, the net cost / time can be lower.
on hiatus
Old 6th May 2010, 06:39 PM   #1194
tresch is offline tresch  United States
Originally Posted by torrence View Post
I actually finished these Floorstander MkII boxes over a year ago. My kids had a real fascination for the exposed drivers, so I thought I would try the Fostex grills. They took some getting used to, but I actually like the way they look now. My wife goaded me into veneering the boxes, which I had never done before, but in the end this was well worth the effort.
What method/materials did you use to veneer these?
Next up, you can veneer your floor!
Old 7th May 2010, 03:42 PM   #1195
torrence's Avatar
I used the white glue + iron technique. Having a square box makes this very easy, as you can just flop the veneer over the edges, then use a router to trim it perfectly flush.
The floor is bare OSB, sanded, and finished with the stuff they put on basketball courts. It looks pretty great in person, and was dirt cheap.
Old 7th May 2010, 08:58 PM   #1196
Martin Prothero's Avatar
Default Fe168ez bib
OK nothing groundbreaking here but a BIB I built 3 years ago and am still loving it!
I have built 2 amps, a DAC, interconnects and speaker cables since but the BIB just gets better.
Fostex driver gives just the right balance for me. The only unusual bit is the binding posts. I designed them to be very simple and allow the use of bare cable (I'm not a fan of bananas). Kind of like Cardas actually but slightly different in design and mine use solid silver washers with PTFE rod and wood (elm) blocks.
Seen from underneath
Without blocks. I made the silver washers from sheet - if anyone knows of somewhere to buy round discs oor silver washers let me know please.
Keep a green bough in your heart, the singing bird will come.
Old 7th May 2010, 10:08 PM   #1197
doorman's Avatar
Very nice speakers, Martin!
It's things like your binding posts that make DIY such a fascinating pursuit!
Well Done--
Don
(your cables look interesting as well)
Old 8th May 2010, 04:26 PM   #1198
Thanks for the comment Doorman. The cables are just 12 pairs of Cat5 all bound up with the outer weave of some artificial silk rope.. I might build something a little more exotic when time allows but for now they do a pretty decent job.
Old 9th May 2010, 10:00 AM   #1199
would have liked to use good quality ply for the curvy chang, but its a cost restrictive thing, its double to triple the cost of MDF! oh and yes, that was the first thing i noticed when the old's moved in to this house... 69! haha
whats the recommended dampening material / amount for this box? i have some nice thick 1" black high density audio foam i found in the scrap at work, otherwise just use either fiberglass batts (ugh) or the polyester fluff fill, uh, fill. if using the foam, I was thinking on the interior - top, bottom and port panels? none on the sides and none on the front panel. hope this makes sense...
Cheers
James
Old 11th May 2010, 08:15 AM   #1200
Talking My first full-range
Full-rang Hemp FR8C 'Tommy Chang'
Copyright 1999-2017 diyAudio
