Full Range Speaker Photo Gallery - Page 11 - diyAudio
Old 21st October 2005, 05:14 PM   #101
sumacSK is offline sumacSK  Slovakia
Send a message via ICQ to sumacSK
Default sp-200x
Hi Cal,
Yes its in centimetres... And I forgot, the lenght of the port is 7.6 cm...
Good luck Martin
Old 22nd October 2005, 12:00 PM   #102
Colin is offline Colin  United Kingdom
Originally posted by smallangryboy
Illusus - cheers
planet10 - as far as I understand it, Ted assembles the drivers, the components are shipped in, though I could be wrong, but I'm not going to split hairs, we source them from the UK, that's close enough for me !
The JX92s are still built by Vifa. Ted tests deliveries and then ships them out.
Colin
Old 23rd October 2005, 03:08 AM   #103
Masuji is offline Masuji  Netherlands
Here some pictures of my other small 5.0 HT system based on the Tangband W3-871s units.
(Lancetta HE in Cyburgh's Needle outfit and 2x CT209 / 1x CT209AL)
All filters applied are the same as the Lancetta High-End version.
All cabinets are increased in outher size for cosmetic resons.
The cabinets are made of 10mm thick MDF, finished with silver paint all arround.
The Needle's have a compartment at the bottom filled with the filter and sand.
Old 23rd October 2005, 10:39 AM   #104
Why the W3-315SC for the center? To me it sounds clearly different than a W3-817S.
Old 23rd October 2005, 11:59 AM   #105
@ Landroval :
The W3-315SC sounds just a little bit different in the middle/high freq.
after an experiment with different units for the centre I found out
that in this configuration the W3-315SC sounds more open and
detailed .
Placed in the Needle the W3-315SC didn't sound that great, to
much, little agressive in the middle.
But for voices, comming over the centre unit it sounds quite perfect.
Old 26th October 2005, 12:01 PM   #106
Ok. I can see your point there. I usually prefer identical L-C-R speakers, but if your way sounds better I see no reason not to keep it that way.
Old 26th October 2005, 10:15 PM   #107
JVA is offline JVA  Canada
to Planet 10:
I listened to Tom Z's horn at Bob's the other day. I found them excellent in the upper range and they had fantastic lower bass. Amazing for that size of a speaker. After listening for a while, we did stuff the horn with some poly stuffing to eliminate the mid-bass honking. I wonder if you found the same problem? I also had to deal with the same problem with my Jordan transmission lines and also had to use stuffing in the vent to remove some of the mid-bass honking.
/Joe
Old 26th October 2005, 10:26 PM   #108
frugal-phile(tm)
planet10's Avatar
Where did you put the polyfluff... the honk in the mids was the most objectionable issue (i still haven't heard the 2nd pair yet)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th October 2005, 02:21 AM   #109
Planet 10
I just stuffed the pollyfill a short distance up the horn opening.makes it easy to remove.
Joe
Old 28th October 2005, 08:45 PM   #110
Send a message via MSN to usa_satriani
Hi there.
I did Nagaoka D58-ES for front speakers and D37 for back speakers using FE208EZ + FT96H and FE168EZ :
http://satriany.free.fr/pages/enceintes/index.php
Greg.
"That's why we like you Mulder. Your ideas are weirder than ours."
Copyright 1999-2017 diyAudio
