Old 26th September 2005, 08:52 PM   #1
mirland is offline mirland  Denmark
Send a message via AIM to mirland Send a message via MSN to mirland Send a message via Yahoo to mirland
Default Fullrange hiss ?
Hi !
I've just completed (?) my first venture into DIYing a set of speakers. I've used 8" Audio Nirvanas in 18L enclosures made from 19mm mdf lined in the insides with bitumen and damped using some kind of sonically correct speaker wool. Wiring is done using Supra Ply 3.6 and the bassreflex is placed as a slot on the front. These speakers have no real low end but they sound exceptionally clear and welldefined. BUT! As soon as there is no sound they hiss very "loud". This is annoying! Have I done anything wrong ? Or is this a characteristic of the fullrange speaker ?
The rest of the setup: Tripath amp (Audio Digit) and Rega Planet 2000 cd player with Rega Couple interconnect and Supra speaker cables.
Any advice is welcome !
/Mirland
Old 26th September 2005, 11:58 PM   #2
Stocker is offline Stocker  United States
Speakers are like computers: they do as they are instructed. You are likely hearing noise or some other auditory "junk" from the signal path. Try changing preamplifiers, sources, amplifiers and see what happens. Worst case, change the power circuit (and / or location) in the house.
Jesus loves you.
Old 27th September 2005, 09:12 AM   #3
Scottmoose's Avatar
If you're worried about picking up RFI, grab some ferrite clamps and stick them on all signal and speaker leads. Alternatively, wrap them in aluminium kitchen foil. I kid thee not. It's not as good as a well engineered shield, but it's very cheap, and if RFI is a problem, it's better than nothing until you can change leads or get the clamps.
My money is that it's your amp that's causing the problem; easiest way to find out is to swap it out for one borrowed froma friend if you haven't got another one lurking around the house somewhere.
Best
Scott
Old 27th September 2005, 09:18 AM   #4
I am also comig to the conclusion that it might be the amplifier. I don't know which is worse
/Mirland
Old 27th September 2005, 02:36 PM   #5
gmilitano's Avatar
My guesses would be that the hiss is caused by the source or amp or having AC power cables or power sources near the speaker wire. If the speakers have a BSC, the problem could also be the passive components.
Old 27th September 2005, 04:31 PM   #6
I just got home and tried out a few things:
1. Changed amplifier: First an Onix OA21s - same level of hiss. Then a Naim Nait 1: Same level once again.
2. Changed speakers using my tripath amp: Hiss at a much lower level.
I am really confused. I would like to think it might be the tripath but I don't think so. My setup should be rather well organized BUT I am missing a dedicated ground spur.
Could it be that the speaker is actually too effecient ? That it multiplies the potential hiss from the amplifier/s ?
/Mirland
Old 27th September 2005, 05:26 PM   #7
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Which amp exactly?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 27th September 2005, 05:47 PM   #8
I hope this link works:
http://www.autocostruire.com/catalog...f73d47f02e88bb
I have constructed a nice steel casing and am using this psu:
http://www.autocostruire.com/catalog...roducts_id=260
However my version is the 5A.
/Mirland
Old 27th September 2005, 06:20 PM   #9
Nuuk's Avatar
Well there is (was?) a known hiss problem with the Fernice amplifier from Autocostruire but not with the version in that link as far as I know (at least the one I have has no hiss).
But the problem is more likely to be with the amp than the speakers so I would contact the supplier and ask if they can suggest anything. (Or ask on the Class-D forum)
Old 27th September 2005, 06:44 PM   #10
pinkmouse's Avatar
Originally posted by Nuuk
But the problem is more likely to be with the amp than the speakers...
But it could be the source...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Why does this opamp hiss? cuibono Chip Amps 2 8th May 2009 11:40 AM
Hiss but no hum... RockysDad Tubes / Valves 13 5th April 2009 05:35 PM
Hiss in my P3a Amp blap0220 Solid State 15 1st June 2007 01:52 AM
hiss jaudio Chip Amps 21 6th March 2005 05:02 PM
Help with Zen Headphone Amp - hiss... batee Headphone Systems 1 8th March 2004 07:14 AM
Page generated in 0.11446 seconds (76.74% PHP - 23.26% MySQL) with 10 queries
