Old 27th September 2005, 07:03 PM   #11
Frank Berry's Avatar
The problem is most certainly with your preamp or your amplifier.
Loudspeakers cannot reproduce "hiss" when none is present within your amplifying system.
Frank
Old 27th September 2005, 07:09 PM   #12
I would say you should check out the wires as well. I know others have mentioned this, but try moving things around a bit while you hear the hiss. Try moving wires or moving components around. Could possibly be a loose connection, but that would most likely buzz. I doulbt it's the speakers.
One other thought is that it could be from something else on the same electrical circuit. Good luck with it.
Old 27th September 2005, 07:18 PM   #13
mirland is offline mirland  Denmark
Send a message via AIM to mirland Send a message via MSN to mirland Send a message via Yahoo to mirland
As I still don't quite know what to do I've also started a thread in the class-d section.
But I've connected the t-amp to another set of speakers (traditional two-way stuff) and there is no more hiss than when I'm using my other amps...
Argh...
/Mirland
Old 28th September 2005, 05:53 AM   #14
Stocker is offline Stocker  United States
The source. CD player. Tape deck. Preamplifier. Source of signal to the amplifier. Change it.
Jesus loves you.
Old 28th September 2005, 11:43 AM   #15
theNoid is offline theNoid  United States
Send a message via Yahoo to theNoid
Ok, I am gonna go out an a limb and bet it's the source. I say this simply because he already switched amps around and still had the problem.
We know it's not the speakers, BUT they could be a bit of a "culprit" here I think. Not havig played with the Audio Nirvana speaks I cannot say for sure but they appear to be like Fostex "sound-alikes" which means they may tend to have a bit of a forward mids and highs ("hiss" frequencies). This forwardness, may be just magnifying the "lesser" hiss you hear in your other speakers.
To recap, he has switched amps and speakers out, eliminating these as the source of the problem, what's left? Source or preamp...no?
Noidster
"Mmmmm......Beeeer"
Why does this opamp hiss? cuibono Chip Amps 2 8th May 2009 11:40 AM
Hiss but no hum... RockysDad Tubes / Valves 13 5th April 2009 05:35 PM
Hiss in my P3a Amp blap0220 Solid State 15 1st June 2007 01:52 AM
hiss jaudio Chip Amps 21 6th March 2005 05:02 PM
Help with Zen Headphone Amp - hiss... batee Headphone Systems 1 8th March 2004 07:14 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
