FE108ESigma
FE108ESigma
Old 8th September 2005, 03:12 PM   #1
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
FE108ESigma
Default FE108ESigma
Hi there,
is 65 Euro, thatīs 80.6$, okay for one FE108ESigma?
Iīm considering buying a pair...
Iīve read a lot about the FE108E and also a lot about designs including this fella, but I havenīt heard a lot about the FE108ESigma.
Any oppinions? Are ther interchangeable? Can I use a FE108E Enclosure-Design with the FE108ESigma?
Thanks for reading, David
Gravity - Making the G since 13.7 billion B.C.
Old 8th September 2005, 08:23 PM   #2
kepa1 is offline kepa1  France
Hi Rodeodave,
I don't know about the FE108S but here is the recommanded enclosure for this driver I found on fostex site:
http://www.fostexinternational.com/d...108ez_encl.pdf
Doesn't look like very straightforward!
Old 9th September 2005, 02:40 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
FE108ESigma
Default Re: FE108ESigma
The FE108ES is one of my favorite drivers of all time. Definitly a step up from the FE108S. It really likes a horn (or a current amp) to generate bass.
With modifications to the compression chamber it can be put into the buschorn II.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th September 2005, 07:00 AM   #4
hates ground loops
Rodeodave's Avatar
FE108ESigma
Default Re: Re: FE108ESigma
Yep, might be true. But I think Iīll give it a try anyway. Maybe Iīll build a downscaled "prototype" out of cardboard first, to see where all the parts should go...
I know that you probably know as little as I do about this design, but a few questions anyway:
The "Sound Absorbents", thatīs damping material, right?
Whatīs up with parts 21 to 25? Why is there only one piece ā per speaker?
What are the "2 - ø20 holes" (on the back, top) for?
Where does the terminal board go?
Originally posted by planet10
The FE108ES is one of my favorite drivers of all time. Definitly a step up from the FE108S. It really likes a horn 9or a current amp) to generate bass.
dave
Yeah, that makes me confident, plus, Iīll be using a current amp, thatīs good.
Thanks for your replies, David
Old 29th September 2005, 12:20 AM   #5
Jaime is offline Jaime  Uruguay
Jaime's Avatar
Rodeodave
“...downscaled "prototype" out of cardboard...”
Loudspeaker boxes can’t be scaled ..!!!!!
You have more information at
http://www.geocities.com/dbr_audio/H...ex_FE108EZ.pdf
best regards Jaime
I write in English worse than Tarzan
Old 29th September 2005, 06:24 PM   #6
hates ground loops
Rodeodave's Avatar
FE108ESigma
i konw that enclosures can't be downscaled if you want a working version.
i just couldn't figure out how the thingy look like in 3D.
plus i wanted to figure out where i should start glueing parts together.
Old 30th September 2005, 12:16 AM   #7
Jaime's Avatar
Rodeodave
in this web you have 3D drawings
sorry, but, it is in spanish
Old 1st October 2005, 11:09 PM   #8
RtV is offline RtV  United States
Rodeodave,
Good questions. Let me add another: Why cut those six blocks just under the driver, only to glue them back together again?
Randy
Old 1st October 2005, 11:52 PM   #9
Jaime's Avatar
The pieces 21-25 are reinforcements.
The littles blocks can change the volume of the cell and tune the sound
Old 3rd October 2005, 07:31 AM   #10
Gluca is offline Gluca  Italy
Gluca's Avatar
HEY RODEODAVE!
May I ask where you are going to buy the FE108EZ? Prices I saw are quite higher than the one you got.
Gianluca
FE108ESigmaHide this!Advertise here!
FS: NIB 2 X Fostex FE108ESigma $80 each dhenryp Swap Meet 4 19th May 2009 03:00 PM
