Which BLH for linear response down to 40Hz? - Page 3 - diyAudio
Old 4th September 2005, 08:21 AM   #21
Default After this I give up
http://www.diy-systems.com/wwwboard/...ry.php?id=9586
This seems to work they must have made an abrieviation of some kind on the post. I tried this address and it works. Regards Moray James.
moray james
Old 4th September 2005, 12:33 PM   #22
Tyimo is offline Tyimo  Hungary
Thanks!!
I already downloaded the plans in a few hours ago.
I don't know whats going on the Net, but I almost lost in the wirtual space..... :-))
Maybe I will try the Singular, but first I am looking for a "true" BLH speaker with ca. 40Hz linear response.
Thanks and Greets:
Tyimo
Old 5th September 2005, 09:04 AM   #23
Scottmoose's Avatar
Originally posted by Tyimo
Hi!
Scottmoose! I belive in the Hedlund and I would like to make some simulation with MJK's software too. In another thread I already asked about the Hedlund's correct measurements, but I will ask here too:
-what is the correct St (3x23cm?)
-what is the correct Sm (65x23cm?)
-what is the correct line lenght?
-what is the horn contour? exponential?
Tyimo
I'll have to dig the data out -its on an old hard-disk that's not in my PC at the moment, but I'll post it in a day or two. It might be a little off, but it'll provide a rough starting point / guide.
Scott
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 5th September 2005, 05:50 PM   #24
Thanks Scott!!!!!
I am waiting!
Greets:
Tyimo
Old 13th September 2005, 02:09 PM   #25
Hi Scott!
Can you find the data???
I have already the original Hedlunds plan, but I don't know what is the real horn line lenght?
Tyimo
Old 13th September 2005, 09:36 PM   #26
squalor is offline squalor  United States
squalor's Avatar
psst...............wanna see my Dallas?
http://fullrangedriver.com/gallery/a...017/Dhorn8.JPG
Old 14th September 2005, 02:38 AM   #27
Default BLH design
Have you looked ar this back loaded horn design by Onur Ilkorur? Excellent fo Fostex Fe206e or AER etc.
http://www.yildiz.edu.tr/~ilkorur/sp...tex_fe206e.htm
moray james
Old 14th September 2005, 10:55 AM   #28
Scottmoose's Avatar
Hi Scott!
Tyimo
Blast! Sorry, I forgot. Will dig it out -expect a post later today. I need to dig some gen. off that old hard drive anyway for my thesis.
Cheers
Scott
Old 14th September 2005, 01:05 PM   #29
Scottmoose's Avatar
Right, found it (at last!).
At the time I did this, I was using Martin's MathCad worksheets to compare the results different horn desings would give using the same driver, in this case the good old Fostex FE206E. Whilst the Hedlund was designed for Lowther drivers, the Fostex specifications are usually relatively close to Lowthers, and I didn't want to introduce another variable (i.e. different driver types) into the comparison. As you can see, the response curve using the 206 isn't too bad. There's a fair bit of ripple, but nowhere near as much as some designs I've seen (and would rather not!) -the Jerrico, and several of the Fostex Factory designs spring to mind as immediate examples. Besides, horns are not known for an overly even response curve!
Approximate dimensions used were: Horn length 129"; mouth area 6.8Sd, throat area 0.25Sd. These were roughly calculated from Jan Hedlund's original drawings -certainly not exact, but they'll be near enough to give a general idea as to what's going on.
With, say, a DX3, I'd expect much the same cut-off point, (or perhaps a little higher) but higher spls below 100Hz -probably dropping somewhat around this point, then levelling off. If I'm correct in guessing this, then the 206 might well be a better match, as it's resonse falls away, but probably in step with room gain.
Hope some of this is useful
Best
Scott
Old 14th September 2005, 01:07 PM   #30
Scottmoose's Avatar
Woofer & Mouth Far-Field SPLs:
really weird linear potentiometers that have a logarithmic response VvvvvV Instruments and Amps 8 30th March 2007 11:00 PM
Which Horn for linear response down to 20Hz? Bass-Depth Subwoofers 81 2nd September 2005 03:59 AM
Active crossover with linear response ackcheng Multi-Way 0 19th July 2004 06:15 PM
Copyright 1999-2017 diyAudio
