W4-1320sb
W4-1320sb
Old 21st September 2005, 08:03 PM   #11
Corloc is offline Corloc  United States
Corloc's Avatar
You like them better than the paper TB W4-616?
The 616 only goes to about 14k with an fs of 65 hz. It's a little hard to compair, because the 1320's are not in optimized cabs yet. The 616 has no top and until I have cabs, the 1320's have no bottom.
Old 22nd September 2005, 08:42 PM   #12
Andrew S- is offline Andrew S-  United States
OK just got mine in the mail yesterday.
Got someone thats going to test them for me so when he is done I will link the Praxis and Klippel reports.
Frequency response and off-axis response
Actual Thiele Small parameters
non-linear distortion analysis
waterfall and/or energy storage analysis
BL/KMS curves
Old 25th September 2005, 04:44 AM   #13
mazeroth is offline mazeroth  United States
Andrew, can't wait!
Old 25th September 2005, 03:01 PM   #14
Josephjcole is offline Josephjcole  United States
Josephjcole's Avatar
Fs 81.839996, Qms 2.121518, Qes 0.674866, Qts 0.511997
Vas = 4.11 liters
Fs 75.559998, Qms 2.049201, Qes 0.601340, Qts 0.464911
Vas = 4.8 liters
Here are the T/S parameters after 36 hours at 20Hz, of the two that I ordered. For anybody who is interested.
Joe
Old 26th September 2005, 09:41 AM   #15
eagles is offline eagles  China
Send a message via MSN to eagles
Default my personal suggustion
I think it is better to cut off the lower frequcy singal under 80HZ for the 3 inches or 4 inches full range speaker, and the sound will turn more pure and clear.
Old 28th September 2005, 06:56 PM   #16
chuck55 is offline chuck55  United States
T-B recommends:
"intended for thin or flat speaker box design"
Here is a 3.5 liter cabinet design from Aan at T-B:
c:\...\w4-1320sb vented box design.pdf
Unfortunately, I can't seem to copy the .pdf file Alan e-mailed me. Here is the best I can do:
File: w4-1320sb.bb6
w4-1320sb vented box design By Eagle Chang, TB-speaker
Ningbo China
+86-574-86553648
+86-574-86551617
Box Properties
--Description--
Name:
Type: Vented Box
Shape: Prism, square
--Box Parameters--
Vb = 3.558 liters
V(total) = 4 liters
Fb = 80 Hz
QL = 7
F3 = 97 Hz
Fill = normal
--Vents--
No. of Vents = 1
Vent shape = round
Vent ends = one flush
Dv = 38 mm
Lv = 111.9 mm
Driver Properties
--Description--
Name:
Type: Standard one-way driver
--Configuration--
No. of Drivers = 1
--Mechanical Parameters--
Fs = 75 Hz
Qms = 1.5
Vas = 5.985 liters
Cms = 1.297 mm/N
Mms = 3.472 g
Rms = 1.091 kg/s
Xmax = 3 mm
Xmech = 4.5 mm
P-Dia = 85.19 mm
Sd = 57 sq.cm
P-Vd = 0.0171 liters
--Electrical Parameters--
Qes = 0.484
Re = 6.8 ohms
Le = 0.01 mH
Z = 8 ohms
BL = 4.794 Tm
Pe = 20 watts
--Electromech. Parameters--
Qts = 0.366
no = 0.503 %
1-W SPL = 89.16 dB
2.83-V SPL = 89.87 dB
Normalized Amplitude Response (dB-SPL/Hz) BassBox 6 Pro
dB
6
0
-6
-12
-18
-24
-30
-36
5 Hz 10 50 100 500 1 K 5 K 10 K 20 K
Custom Amplitude Response (dB-SPL/Hz at 1 m) with 20 watts BassBox 6 Pro
dB
109
103
97
91
85
79
73
67
Maximum Acoustic Power (dB-SPL/Hz at 1 m) BassBox 6 Pro
dB
108
102
96
90
84
78
72
66
Old 17th October 2005, 03:07 AM   #17
trying again with a link
Old 13th December 2005, 04:54 PM   #18
happy.gringo is offline happy.gringo  Costa Rica
happy.gringo's Avatar
Default anymore work on these designs?
Hi Guys,
I am going to bring back a pair of these from the States and I would like to build a simple design that could either pair with a sub or stand alone at fairly loud volume. Have you reached a design that you are satisfied with? If so, could you please share particulars?
Thanks.
Old 13th December 2005, 06:32 PM   #19
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Smile Bamboo...
http://www.zillaspeak.com/Bamboo.asp
I have been enjoying mine. I stained the boxes last night and applied the first coat of poly...
I like their sound alot. But they sound better in the much larger pipe so i feel a different box can maximize performance.
Peace,
Godzilla
Old 14th December 2005, 02:26 AM   #20
Nice looking speakers! Why the cap + resistor? Near the wall don't see why they would need baffle step correction. Have you tried towing them in more to get more HF?
Mine are in 3.5 liter box with 1" dia x 4.4" long vent. Finish them by X-mas I hope.
W4-1320sbHide this!Advertise here!
FS TB W4-1320SB Bamboo drivers and more saabracer23 Swap Meet 0 15th August 2007 07:02 AM
FS: TB W4-1320SB FR Drivers saabracer23 Swap Meet 4 14th May 2007 03:27 AM
WMTMW using the TB W4-1320SB saabracer23 Multi-Way 2 13th April 2007 05:21 PM
Tang-Band W4-1320SB - almost new chuck55 Swap Meet 2 28th January 2006 02:35 PM
W4-1320SB Golden Ratio BR sharpi31 Full Range 4 8th December 2005 10:50 PM
