5" overall full range ??  FX120A or FR125S
Old 23rd August 2005, 11:01 PM   #1
newtitan is offline newtitan  United States
Default 5" overall full range ?? FX120A or FR125S
okay is order time , and I have read all the reviews much that my eyes hurt
need some experience help
im going to try something different
using them in my car--up high in the pillars semi-sealed (polyfill stuffed )
strict 100-20K, with a tweeter coming in for helper duty at 5k--to help with the poor off axis support
which would work best in this application?
they both have not so great off axis support
but its up high on the dash so sensitivity is not that important
the fostex sensitiviy looks appetizing--but I read in some review that there is a significant dip in the 200hz range??)
but then theres the xbl2 low distortion in the midrange
and yes I know neither one is really a car driver, but im being adventurous
imleanign towards the FR125S, but do others think the fostex is the better driver for this less than ideal application?
Old 24th August 2005, 01:42 PM   #2
robertG is offline robertG  Canada
I would go with the FR125S. Honestly, I think that the Fostex is the best driver between the two, but in a car, I'm not so sure it will hold up.
Also, I've been playing with the FR125S and it has great dispersion, more excursion, silky mids and looks rugged. It's not as detailed as the Fostex and it's really not efficient, but this should not matter in a car - unless you plan to install a low power tube amp :^)
Old 24th August 2005, 01:54 PM   #3
Samuel Jayaraj is offline Samuel Jayaraj  India
I was intending to ask a similar question though not for car use but in the home as a real hi-end reference speaker.
What other speakers (preferably Full Range, lower frequencies being catered by a Subwoofer) are out there which sound more detailed than the FX120A, at a similar price?
I am aware of Jordan, Supravox and Lowther. Any others? Thanks.
Sam
Old 24th August 2005, 09:03 PM   #4
one1speed is offline one1speed  United States
I would go for the FR125s. I'm not sure you'd notice much difference in a car with all the noise and such. I doubt you'd see the benefits of the better driver. Plus, the magnet assembly of the Fostex may become a bit cumbersone to work with.
Old 24th August 2005, 09:13 PM   #5
zobsky is offline zobsky  India
zobsky's Avatar
if you're going to use a seperate tweeter (preferable in an automotive application), use the cheaper WR125s
make sure you don't feed low frequencies to prevent wild cone gyrations
also, be aware of the lower eff. of the CSS drivers, . .. the WR, while a nice driver, just didn't have enough volume when I owned it. I was tempted to buy a second pair, but that would have put me above budget.
that apart, .. i'm not entirely convinced that these drivers aren't wasted in an automotive environment
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 24th August 2005, 10:26 PM   #6
thx guys for all the heads up
I think im going to stick with my original plan and try out some revelator 4.5" jsut make it an easier drop in for my spekaer pods
always wanted to hear them anyway
Ill try the full ranges for the computer speakers
Old 26th August 2005, 10:29 PM   #7
ABS is offline ABS  United States
One thing to keep in mind is that the revelators are not a high Q driver - they are really optimized for a ported enclosure. The WR125S is a high Q driver which means that the cone will be better controlled and will provide richer bass in either a free air or semi free air condition. Additionally, the extended frequency response of the WR125S will probably give you better performance in a car situation without having to design a complicated cross-over. If you are using a reasonably powerful amp with the WR125S your performance should be good enough. I can tell you that using 7" Seas G18 drivers in my car has proven to be a difficult proposition largely due to the low Qts of the driver and the poor off-axis response above about 2.5K. Having extensively tested the WR125S in a 2-way mini-monitor I designed I must say that I am highly tempted to install those drivers in my car instead of those Seas woofers . . .
Good luck whatever you decide to do.
Andrew
Old 27th August 2005, 10:43 PM   #8
youyoung21147 is offline youyoung21147  France
Send a message via MSN to youyoung21147
I own a pair of FX120 (like the F120A but not shielded) and love them. Very detailed, sweet, and natural.
But in a car I 'd prefer a more solid speaker because the fostex handle only a few watts and have a way too low Qts for this kind of application. The foam surround may not like high powers !
They cannot reach more than 100dB anyway, and need an enclosure to hold the cone firmly.
Fostex F120A speaker pair for sale - 250 only !
5" overall full range ??  FX120A or FR125SHide this!Advertise here!
Favorite Threads and Posts in "Full Range" Variac Full Range 16 22nd October 2017 01:42 PM
1.5" - 2" full range weather resistant speaker? eRiCdWoNg Multi-Way 0 1st May 2008 07:12 PM
FR125s FULL RANGE DRIVERS FOR SALE Thomo Swap Meet 2 20th April 2007 12:51 AM
Kofi Annan in: "Flippin' the Full Range!" Kofi Annan Full Range 14 1st June 2005 03:07 AM
what makes a loudspeaker "full range"? kneadle Full Range 25 15th April 2005 07:53 PM
