Old 23rd August 2005, 03:32 PM   #1
JRKO's Avatar
Send a message via AIM to JRKO
Default Eclipse TD712z
Has anyone heared these?
They are single driver units and supposedly FR with amazing imaging. The cabinet is a complex casting with various parts including a clemping system for the driver with a weight that is larger than the driver/magnet assembly to damp all unwanted resonence. The dtiver is 12cm.
www.eclipse-td.com/e34_td712z/index.html
How good are they? They retail for £3000!
Could the design ideas be used to get the very best from a single FR driver in a diy cab?
In the interests of full disclosure JRKO = James Rupert Kingsley Osborne. And yes, my parents will pay for it when I choose their retirement home
Old 23rd August 2005, 04:30 PM   #2
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I wonder if good quality bass is possible with enclosures like that?
Hear the real thing!
Old 23rd August 2005, 05:39 PM   #3
JRKO's Avatar
Default Explosion
Boom
Here is the unit opened up.
Old 23rd August 2005, 05:44 PM   #4
JRKO's Avatar
notice the large weight directly behind the driver.
It extends into the pole peice vent. It is tapered at the back, not only to fit the casing but to break up any remaining standing waves that the rear shell did not already kill. So the driver essentially never gets a wave refletion hitting it
The frame with the legs bolts to the front section of the cabinet and secures the DRIVER directly to the stand!
Old 24th August 2005, 12:47 AM   #5
soongsc's Avatar
It looks like a closed box system to me, don't see any vents used to extend base?
Old 24th August 2005, 06:02 AM   #6
JRKO's Avatar
spec sheet says
6ohms
83.5dB/W/m
40Hz-20kHz
I hae no idea if the box if vented or not. All I know is that they have made a lot of effort in minimising vibrations, damping the driver and making the hole shebang as dead as possible.
If problems like internal reflections, vibration etc are minimised as much as possible I guess the driver can give its best.
Also having such a small (read no) front cabinet area the driver must be extreemly directional.
40 Hz is pretty low, especially for a 12cm driver in such a small (assumed) sealed enclosure.
Would taking ideas to get the driver as stable as possible make a major difference?
Also these guys follow 'time domain theory'
I dont get it
Old 24th August 2005, 09:05 AM   #7
soongsc's Avatar
With that kind of effeciency, it might be possible with a full range driver.
Old 24th August 2005, 09:21 AM   #8
JRKO's Avatar
I was thinking of a W3-871S to start with.
Old 24th August 2005, 10:47 AM   #9
soongsc's Avatar
That's a lot smaller than 12cm.
Old 24th August 2005, 11:44 AM   #10
JRKO's Avatar
I was going to try to implement some of the ideas in a smaller and cheaper speaker and then try it with something bigger.
Do you have any other ideas for drivers?
I was thinking about a translam cabinet to make the shaping easier using glass fibre on the inside and outside to make it stiffer. I will try to get a friend who has a lathe to turn a hunk of something he has laying around for the rear weight/phase thingy!
How does that sound?
Eclipse 3121 spooney Car Audio 0 23rd November 2007 12:37 PM
CD8053 Eclipse corradolvr Car Audio 4 8th September 2007 06:14 PM
eclipse problem mike49504 Car Audio 2 16th April 2007 07:35 PM
Eclipse Brian Donaldson The Lounge 5 28th October 2004 08:32 PM
Eclipse? Larr_e_boy Multi-Way 0 7th June 2001 02:41 PM
Page generated in 0.48878 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
