CSS FR125S for center channel ?
Old 22nd August 2005, 04:22 PM   #11
MCH is offline MCH
Thanks for all the input.
I think I'll go with 1 driver for the center channel. My question now is the cab design. Is the Aperiodic 4liter style a good choice for this application? The 13 liter mini Onken design that I used for the mains is a tad too large and bulky looking for a center. Laying it on it's side might work though. But I don't know if this is detrmental to the sound.
Also would the Aperiodic integrate with my mains? Keep in mind that these will be utilized with a sub crossed over at a 100hz.
Old 22nd August 2005, 04:42 PM   #12
morbo is offline morbo  Canada
I will post a picture of my center channel tonight. Off the top of my head - its 12" wide, 6.5" tall, and 18" deep or thereabouts, with a single shelf brace along the longest dimension. Rear ported, tuned to ~50hz. If I was doing it again, I'd port a bit higher and the box could be either narrower or shallower.
Old 22nd August 2005, 05:00 PM   #13
audiobomber is offline audiobomber  Canada
audiobomber's Avatar
I'd use a sealed .25 cu ft box, crossed to the sub at 80 Hz:
Q= .86, F3= 78Hz.
Dan
Old 22nd August 2005, 06:37 PM   #14
Landroval is offline Landroval  Finland
Q= .86, F3= 78Hz.
What parameters and software are you using. I'm getting .25 cu ft box Q = .75, F3 = 90Hz with WinISD Pro.
Old 22nd August 2005, 06:47 PM   #15
Hmm, this isn't the first time this has happened. I'm using WinISD beta #0.44
Qts = .64, Fs = 68, Vas = 5.8 liters.
Dan
Old 22nd August 2005, 07:17 PM   #16
Ok. Those are for WR125S/ST. FR has Qts = 0.56, Fs = 67.4, Vas = 5.58. So maybe that's the difference.
Old 22nd August 2005, 07:53 PM   #17
Sorry, I thought I'd read somewhere that the specs were the same except for frequency response.
I tried again with WinISD version .44, using the proper FR125S specs, and I got F3= 86Hz and Q=.75
Anyway, a sealed box makes a lot of sense for a center channel when crossed to a sub, don't you think? According to Dickason, "If you cannot get an enclosure resonance from a TL or vented type configuration at least two octaves below the crossover frequency, use a sealed configuration."
Dan
Old 22nd August 2005, 08:29 PM   #18
100% agree. I would probably build a sealed center even without a sub. You can also go from 0.25 cu ft easily to 0.15 cu ft without sacrificing much at all.
Old 22nd August 2005, 09:11 PM   #19
Me too! Center channel locations are usually compromised, in which case a sealed box won't be as problematic as a port. Less tendency to boom.
Dan
Old 23rd August 2005, 04:02 AM   #20
MCH is offline MCH
OK. I think I've decided on the cab volumes. I think I'll use the .25 cu.ft (7 liters) for the center . For the surrounds (hang on the wall for my application) I'll use the .15 cu. ft (4.25 liters). I'm sort of lost on all the calculations above; but I assume there seems to be an agreement that these will work fine in the cab volumes I've described.
thx for the input.
CSS FR125S for center channel ?Hide this!Advertise here!
center channel?? wicho Multi-Way 1 25th October 2008 01:01 AM
Center channel with one mid Buzzy Multi-Way 11 17th October 2008 03:52 PM
Center channel 66Panel Multi-Way 0 25th August 2008 03:48 AM
T-amp for Center Channel? atleer Class D 3 6th August 2007 04:56 PM
DIY Center Channel DKAudio Multi-Way 9 2nd June 2006 09:46 PM
