Has anybody used these in anything? From what I can tell, they seem like quite nice little wide-range drivers, except for the horrible efficiency (80db 1w/1m). The huge excursion (20mm p2p) would lead one to think that, hey! we might actually get some bass out of a 3" driver! I'd really like to know if that's the case! And if they're decent (decent, mind you. I don't expect them to be great), what might be the best application? They're cheap too...only $19.80 at madisound.
Any information and/or reccomendations would be wonderful! Thanks in advance.... mista2 http://www.aurasound.com/pdf/NS3-193-8A.pdf
#2 |
http://www.zaphaudio.com/minitest/
http://www.zaphaudio.com/audio-speaker20a.html http://www.zaphaudio.com/audio-speaker20b.html Great information from a great guy. Also, a GREAT little driver! |
#3 |
...tons! Got my pair on order as I type!
#4 |
Don't thank me, thank Zaph
#5 | |
...Thanks be to Zaph!
#6 |
frugal-phile(tm)
The NS-3 is a good little driver. I've been enjoying a set of Illusus' prototypes for the last couple weeks.
You won't get real bass, but enuff to reach down to a sub if you need to. We tried them briefly as bipoles. Impedance curves give an Fs of just under a 100, and the bipole in the same box about 20 hz higher. I plan on adding an aperiodic port to the back baffle to see if i can lower the bipole's impedance peak. Now using them with a sub. XO currently set to 60 Hz. Very satisfying performance. Using a BGT GC in a Specialized Kits chassis. They start to strain a bit when pushed. Very cute too. Very versatile. Cheap & small enuff to use as computer speakers. If you can except its efficiency & loudness restrictions and 100 Hz is good (or you have a sub) these make good mains (make good centres & surrounds too). They'd make a killer mid. if you could find drivers inefficient enuff to suit (or bimap!!) dave PS: speakers packing taped to the stands
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
frugal-phile(tm)
Back baffle
| New Aurasound NS3 2-way | Timn8ter | Multi-Way | 19 | 16th December 2012 02:39 AM |
| Aurasound NS3-194-8E | Mikael Abdellah | Full Range | 13 | 5th August 2007 04:51 PM |
| Aurasound NSW1-205-8A | BoH | Multi-Way | 1 | 11th July 2007 05:26 AM |
| Aurasound | Tristanc1 | Multi-Way | 0 | 3rd March 2006 06:37 AM |
