Telefunken OB's finished - diyAudio
Old 17th August 2005, 02:29 PM   #1
Stixx is offline Stixx  Germany
Stixx's Avatar
Smile Telefunken OB's finished
Hi all,
it's been quite some time since I posted the last time....
Well, my new open baffles are finally finished, the carpenter really took his time...%&"!!
This is my interpretation of the theme "transparent baffle", sort of juggling with baffle area and esthetic "impact". They are now 120 cm high and around 60 cm wide, including the wings. The wings are made from 10mm plexi (isn't that lexan over in the US?) and attached with small dowels (?), the baffle itself is 19mm pearwood.
To have the possibility to try different drivers and to NOT have holes in the front I came up with a mounting device made from 5mm aluminium that also allows different clamping forces of the driver from zero to destruction .
Drivers are the venerable Telefunken 8"ers from 1953 with the big magnet and Saba tweeters. The lower Qt of the Telefunken makes for a slight rollof to the lower regions, but with my closed subwoofer for the bottom bass quality is outstanding...very fast and no booming whatsoever!
Sound quality overall truly is the best I ever had....very easy and reveilling, you are sort of looking into the music!!
regards,
Oliver
Old 17th August 2005, 02:31 PM   #2
Stixx's Avatar
Default backside
rear
Old 17th August 2005, 02:32 PM   #3
Stixx's Avatar
rear2
Old 17th August 2005, 03:09 PM   #4
Scottmoose's Avatar
You, good sir, have yourself a fine project there. But you didn't need me to tell you that, did you? I keep wanting to try a proper OB project, but the present room is too small to pull them much more than a foot from the room boundaries. Pity -I love the freedom from all boxiness you get with the dipolar (and bipolar, come to that) sound.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 17th August 2005, 03:13 PM   #5
biarritz's Avatar
Stixx,
I love your woodwork and the mounting device. I realy would like to hear those beauties.
I have also a pair of Open Baffles which are still under development.
I use Richard Allan CG8t (1973) or Philips 9710m (1971) drivers.
The baffle size is 120cm x 40cm, but I also want to add some wings to the back of the baffle.
I have two BR subs which are integrated in the lower part of the Open Baffle and a digital crossover to experiment with the frequencies. Each sub uses two 6.5" drivers. These are just temporary drivers.
At what frequency do you cross with the sub and what kind of sub do you use?
Low Budget Pat
Grt,
Patrick
Old 17th August 2005, 05:38 PM   #6
Stixx's Avatar
Hi Patrick,
I only have one sub that I built 4 years ago. It is a closed cabinet of 39 litres using an Alumapro Alchemy 12" as driver. This is an awesome driver with perfect TSP for a closed cabinet. Power comes from a Hypex HS 200 (which is manufactured in your homecountry...).
Xover frequency is at around 65Hz, and extends down to 28Hz or so....
Groet,
Oliver
PS Nice headamp you got there....I am currently building the Morgan Jones!
Old 17th August 2005, 07:01 PM   #7
Hi Oliver,
nice cap you have in your highpass section.
What typ you use for it. I mean the tube.
Greetings,
Andreas
PS: Really wonderfull design and workout.
Old 17th August 2005, 07:18 PM   #8
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
Oliver, they look excellent! What is the purpose of the tube on the back?
"A squid eating dough in a polyethylene bag is fast and bulbous, got me?"
Old 17th August 2005, 07:42 PM   #9
Stixx's Avatar
Default tube
Andreas, Ropie,
the tube on the back acts as vacuum cap, I think its an ECF 80 from Telefunken. To try that was suggested to me by Holger Stein from steinmusic.
Although the cap has only a few pF between the plates (?), it audibly improves transient response and resolution of microdetail.
Now those vintage Saba tweets have amazing resolution and natural timbre (how I love all those important words... ), short... it sounds bloody good!
best regards,
Oliver
Old 17th August 2005, 08:31 PM   #10
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Nice work Stixx! The open-baffle army is growing each day!
And it's amazing how many variations on this theme there are!
Could you explain this vacuum cap circuit to us a bit more please?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Oh man, my telefunken stoops... Cassiel Tubes / Valves 14 20th October 2005 05:23 PM
Telefunken TR-1500 anatech Solid State 7 15th October 2005 09:13 PM
Telefunken? Swalabr Tubes / Valves 7 19th June 2004 07:26 AM
Telefunken Tuner/amp coffin Analogue Source 0 4th April 2004 01:34 PM
Copyright 1999-2017 diyAudio
