Interesting new fullranger from CPC (UK)
Old 17th August 2005, 09:39 AM   #11
bigwill is offline bigwill  United Kingdom
They might arrive later today, I'll report what they're like
Old 17th August 2005, 09:48 AM   #12
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Standing by Bigwill!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 17th August 2005, 11:32 AM   #13
Colin is offline Colin  United Kingdom
>The only commercial design that I know of was the one using a single Jordan driver and no crossover. I would love to have heard those although I know they lacked bass!
Hi Nuuk
I've heard these and they sounded very clean. Limited in the bass (but then they were using the JX92 in only 3 or 4 litres, so it would roll off below 100Hz anyway). I prefered them to the same driver in a traditional MDF box, which sounded slow and woolly by comparison.
Wharfedale produced some designs in the 80s which used polystyrene skinned with formica. Never took off, as far as I know.
I've also heard RA's implementation of his idea using Torlyte. Again, very clean sound at high volumes and disconcertingly light when you moved the boxes around. A pair of my enclosures use his chipboard and insulation board construction method.
There is a silver foil-covered building insulation board which is available up to 3" thick which looks like it would not be difficult to work with. (This could be the subject of a whole new thread.)
Colin
Old 17th August 2005, 11:40 AM   #14
Nuuk's Avatar
As do my current IPL A2 enclosures!
And you can buy foam of different density too! It is made primarily for the mock-up industry, eg for making a model of a product for display purposes, or making a design like a car, just to see what it looks like.
Somebody kindly sent me some samples of this stuff and it is a lot more robust than the building type that we have used so far. You can even screw into it! It's more expensive though and I am still looking for an outlet where you do not have to order in bulk quantities (unless we can convert everybody and do a group buy)!
Old 17th August 2005, 04:12 PM   #15
Taperwood is offline Taperwood  United States
Colin
Perhaps you missed the "my Fostex FE108 Sigma Project" thread. It's probably back five or six pages by now. I thoroughly reveal my ignorance, but there are lots of pictures. I've already built five prototypes out of that very same foam (1/2 inch, though). In my last prototype, I used a piece of 4 inch PVC pipe for the compression chamber. I just wish I could get someone else to listen to these. I'm not sure I can trust my judgment, given the "it's my baby" syndrome.
Doug
Old 17th August 2005, 04:23 PM   #16
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Doug
Question: do you like the sound?
If your answer is yes, who cares what other people think? We all like different things anyway. That's the hard-nosed reply. But then again... I know the feeling. It's nice to have other views too. When I stuffed my Tannoy Golds into an 8 foot Voigt pipe (before I knew any better), I loved the sound right up until I measured it. Then, just to clinch things, a friend asked very sweetly why she couldn't hear several voices she'd heard before on the recording though a cheap pair of Wharfdales.
For what it's worth though, I still reckon, if it's the X-baffles you built (?) you're onto something good with those.
Cheers
Scott
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 17th August 2005, 04:43 PM   #17
Oh yeah, Scott, I love the sound, but as you pointed out, it was a friend who clinched it for you that something was not quite right. My wife is no help. She listens for five seconds when I AB for her, says "that one," and walks out of the room. Anyway...
Yes, I'm still futzing around with the X-baffles. Prototype #3 is still my best effort, but #5 reveals more clarity in the mid-range at the expense of bass extension, losing quite a bit below 100hz.
And I apologize for completely hijacking this thread.
Doug
Old 17th August 2005, 07:25 PM   #18
The speakers will now arrive tommorow, since the delivery man failed to knock on the door or anything when he arrived today (just as I realised he was outside and rushed to the door he drove off!)
Old 17th August 2005, 09:32 PM   #19
Nuuk's Avatar
Don't you just hate that and why do they do it? They only have to come back again!
Old 17th August 2005, 10:51 PM   #20
seanzozo is offline seanzozo  United States
The other day I saw some material that was 1/4in ply faced (both sides) with about an inch of pink polystrene foam in between, it even had intermittent glued? 1/16 inch wood running from the front ply to the rear ply segmenting the foam into cells. I have no Idea what it is used for...a sample was at the UT Austin materials lab. It looked expensive.... I lusted appropriately.
Sean
Sean
Interesting new fullranger from CPC (UK)Hide this!Advertise here!
von schweikert unifield 3, an offshoot from "fullranger with helper woofer" d to the g Multi-Way 15 24th September 2008 11:34 AM
Pioneer BOFU, 8" fullranger problem gychang Full Range 34 24th December 2007 08:56 AM
Please list your favorite vintage fullranger JandG Full Range 6 30th June 2007 02:11 PM
What to build next (or, convince me to try another fullranger)? leadbelly Full Range 16 27th March 2007 11:34 PM
Edge diffraction with fullranger badman Full Range 1 1st September 2006 05:57 PM
