Old 17th July 2005, 04:10 PM   #1
el`Ol is offline el`Ol  Germany
Default fullrange dipole with Qts 0.25
Hello all!
My task was to build something that sounds like an open baffle but doesn`t need that much space. And now I managed to build a dipole from a Qts 0.25 driver standing directly in front of the wall. Pictures of my design will follow soon, but first I want to know whether there is anybody else who managed to get bass out of a Qts 0.25 driver in a dipole.
Greets, Oliver
Old 17th July 2005, 06:57 PM   #2
Hallo Oliver,
you should try a currentsource or add a large resistor in series with the output of your amp (you will loose some power ca. 12 Ohm).
So bette go for a current source.
Andreas
Old 17th July 2005, 07:54 PM   #3
AJinFLA is offline AJinFLA  United States
Banned
Hi Oliver,
there seems to be a common misperception regarding the Qts of a driver when used for Open Baffle. A lower Qts (0.25) only means that you will require more eq than a high Qts driver to maintain a flat response. It has absolutely nothing to do with "how much" bass can be produced. That is determined by other factors, such as the drivers Sd, xmax and the path length difference for your acoustic short circuit. You made no mention of these for your driver.
Another common issue for those who want OB (dipole) but lack the space to do so, is control of your rear wave. One possibility is to heavily treat the area behind the speaker, if it is to be relatively close to the rear wall. This can be effective for upper frequencies, but less effective for the lowest. You could try an OB that does not extend too low in frequency, then use a sub for the lowest.
Another alternative is a cardioid. Using a u-shaped baffle and acoustic absorbers to reduce the resulting resonance peak. Gradient uses this method in their speakers. John K uses a cardioid sub for his NaO design.
Good luck and please post some pics of what you have done.
AJ
Old 18th July 2005, 02:34 PM   #4
GM is offline GM  United States
GM's Avatar
Greets!
FYI, you created either a BR or TL depending on the baffle's dims, not dipole. Position them well away from the walls/corners to make them dipoles and hear your LF disappear due to the low Qts.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 18th July 2005, 03:42 PM   #5
Rudolf is online now Rudolf  Germany
Rudolf's Avatar
Default Re: fullrange dipole with Qts 0.25
Hi Oliver,
My personal record holder is Timo alias "tiki", who built a W-frame dipole sub with two Isophon PSL 385/400. Qts=0,17
Timo has documented his dipole here (sorry, its all German ):
http://www.hifi-forum.de/index.php?a...ack=&sort=&z=2
Another guy putting his OBs against the wall is another Timo, who presents his "SOS" in the Visaton forum (again German spoken only):
http://www.visaton.de/vb/showthread....threadid=10090
So it seems your approach is a very "teutonic" one
www.dipolplus.de
Old 18th July 2005, 04:54 PM   #6
Here..
Old 18th July 2005, 04:55 PM   #7
are..
Old 18th July 2005, 04:56 PM   #8
..the pictures.
Old 18th July 2005, 05:03 PM   #9
The speakers are attached to the wall. Angle is 30°. Drivers are FE126E. They sound like OB, not like BR or TL. The 2/3 tube forms some kind of horn. Bass is ok, I don`t find a sub necessary. Unfortunately the treble is far behind my Ciares, I would try the Supravox 135LB instead of the Fostexes next time.
Old 18th July 2005, 06:20 PM   #10
Banned
Wow, that close to the wall! That setup looks more like some sort of TL ,venting at the top, I can't see OB there. Is the cylinder solid? The only scenario I can think of in that situation would be a flat panel baffle with your driver and lots of acoustic absorbtion on the wall behind. The frequency range of that tiny driver won't extend too low, where the absorbers have the least effect. Good luck!
AJ
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 5 21st May 2009 12:10 PM
(WW) MMTMM dipole – 4 vs 3 way / dipole benefit frequencies? charliemouse Multi-Way 25 7th July 2007 11:19 PM
Designing a fullrange dipole? Kensai Full Range 10 6th January 2006 03:49 PM
When is a dipole not a dipole anymore? Bas Horneman Multi-Way 5 5th December 2003 03:02 PM
Fullrange IB with Dipole Sub taufern Multi-Way 16 1st June 2003 01:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
