#21 | |
Good work. With regards to the thin sound, you can try experimenting with some different tweeters. A cheap tweeter with about 1uF may do the trick. See the following links for more info about the Pioneer driver. http://melhuish.org/audio/DIYBX16.html http://www.passdiy.com/pdf/cs-amps-speakers.pdf There is a lot of good information in the above two links. Let us know how you make out.
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#22 |
After reading this thread I decided to screw around with some B51 drivers I had from an old project. I whipped up a pair of bass reflex cabs tuned to around 50 hz, and slapped in the drivers. Not bad at all. The bass is impressive for a FR driver, and the overall presentation is smooth and inoffensive. Doesn't need much power either. It really cries out for a tweeter though. Good bang for the buck.
#23 |
jeremym,
I was in search of a reall full range driver for many months and the only driver I could come up with was the discontinuesd FX200. That is what modelled best of all the drivers I looked at. I've decided I like ull range drivers more than multiway speakers. I decided to try adding a tweeter, it was an old technics horn tweeter I had laying around, but I am pretty happy with the results. I tried seeing just how loud these pioneers go, and man do they get loud. They can handle a lot of power, a lot more than the wr125s. I was unaware the pioneer was one the single driver website, I thought I read the entire website, but I guess I missed that one. Thanks, Josh |
#24 |
diyAudio Editor
Nelson - What the heck are you going to do w/ 200 of those drivers?!!!
#25 | |
#26 | |
"With a high impedance source, say 8 to 15 ohms, it does quite well." So Nelson is probably going to offer these Pioneer FR drivers in a custom designed box along with the F3 amps OR the F3s could be part of an active speaker system (with a single speaker, ofcourse) like Nelson's other active speaker, viz., Rushmore. By the way Nelson, David Dicks must have got in touch with you regarding his Audio Nirvana 8" dual cone offerings. Have you been able to test these and compare them with the Fostex 8" drivers? Thanks for the input.
Sam |
#27 | |
The one and only
them with F2's for guys who want to build some boxes and get their feet wet. And we do have a pair of the Audio Nirvanas on the way. |
#28 |
Well by now these speakers are definately broken in and sound pretty good. The lower midrange/upper bass is great and one of my friends want a pair.
I was wondering what removing the wizzer would do to the sound? Will it, by any chance, liven up the upper midrange or lower treble like I've heard it does to other drivers? Thanks, Josh |
#29 |
diyAudio Editor
If you had 200 pairs you could find out!
Actually I have a pair now too and am suddenly a lot more interested in people's ideas. Anyone else recently used these droivers? |
#30 | |
try a coat or two of damar on the whizzer / main cone if you want to play around with altering the tone of these speakers. if you really wanted to get adventurous, ...try horn loading the b20 (it's a low qts driver anyway)
"Any fool can know. The point is to understand" - Albert Einstein |
| Pioneer 8" B20 | WORS | Full Range | 212 | 13th September 2010 05:48 PM |
| Help with my "new" Pioneer SX 1250!!!!!!!!!!!!!!! | next61 | Solid State | 9 | 3rd October 2005 09:04 PM |
| ATTN "Curtis M" - Pioneer DEX-P78? | EnvisionAudio | Car Audio | 0 | 9th January 2005 11:31 PM |
