Basic help with HiVi B3S design needed
Old 14th July 2005, 11:39 PM   #21
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
OK then you dont want a weeter. Shall I say the magic phrase? Bessel array.
Old 19th August 2005, 12:09 AM   #22
Landroval is offline Landroval  Finland
jimbo1968, what kind of solution did you end up with? Did you try the bessel array?
Old 19th August 2005, 12:13 AM   #23
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Hi Jim, did you source the Hi-Vi drivers from the UK?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 19th August 2005, 10:27 AM   #24
joensd is offline joensd  Germany
If you donīt find a source in the UK:
http://www.spectrumaudio.de/ in germany has them at 20,50€.
greets
jens
Old 19th August 2005, 06:44 PM   #25
jimbo1968 is offline jimbo1968  United Kingdom
I haven't looked up Bessel array (I've been busy, and hadn't visited this thread for a while).
I have built 1 cabinet with 4x b3s. It took longer than I thought because I had to build a jig to cut the angled sides.
I got a bag full of b3s when I was in US recently.
I won't post any comments on how it sounds because I've not tested it. To be honest I'm not sure if I could tell a good speaker from a bad one, at the moment I'm living with those little b3s satellites sitting on top of mono subwoofers crossed at 160Hz and I can't say I'm unhappy with the high frequencies. (And my high frequency hearing is better than most).
Basic help with HiVi B3S design neededHide this!Advertise here!
HiVi vs Peerless new speaker design guru_jeff Multi-Way 1 13th June 2015 06:07 PM
basic BTL design needed 28VDC military job opcom Class D 3 2nd June 2008 03:37 AM
Preliminary HIVI B3S design Zaph Multi-Way 65 18th January 2008 09:12 AM
sub needed to go with hivi B3S jaygeorge1979 Subwoofers 20 3rd January 2006 11:10 AM
Help with HiVi subwoofer needed Christof Subwoofers 8 22nd October 2004 02:47 AM
Copyright ©1999-2017 diyAudio
