W3-871S Monitors Finished! - Page 6 - diyAudio
Old 4th August 2005, 04:06 PM   #51
Send a message via AIM to Chris8sirhC
I'm not sure man, I just thought id let you see what an unfiltered 871s looks like. The spaker was measured in a normal room with no room treatments at all. From 150-200hz on down its not going to be that accurate anyway. We did one measurement with the mic about an inch away and it measured ruler flat all the way up. Id say over most of the freqency range it was +/- .5db no peaks or anything like that(lower midrange and up).
Old 17th August 2005, 10:54 PM   #52
AdamZuf is offline AdamZuf  United Kingdom
Send a message via ICQ to AdamZuf
How good will these serve as studio monitors?
I have a subwoofer.
Old 19th August 2005, 02:20 PM   #53
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
I finally hardwired the notch in place after admitting defeat to its necessity: http://www.vikash.info/audio/W3-871S/listening.asp
Adam, I wouldn't have thought these were suitable for studio monitors.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 19th August 2005, 02:47 PM   #54
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Win some - lose some Vikash! With a bit of luck you will forget it's there after a while and just enjoy the sound!
That's what happened when I added the compensation circuit to my OB's. I didn't like adding something else in the signal path but after a week or two I forget that they were there.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 19th August 2005, 03:08 PM   #55
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I guess it's because of baffle diffraction? I experienced similar situations until change in baffle shape and driver location.
Hear the real thing!
Old 20th August 2005, 10:38 PM   #56
Vikash's Avatar
It may well be. John makes a point of the first design with more effort gone into baffle diffraction so I guess that would be a fair judgement George. I very much would like to compare with John's preferred design to how much all this diffraction malaki actuall makes. (are you reading this John? my postal address is... )
I tried living with them off-axis where IIRC the response is better unfiltered. But wasn't satisfied with that.
Old 20th August 2005, 11:34 PM   #57
Why is that?
Old 21st August 2005, 12:08 AM   #58
soongsc's Avatar
It looks like you are using wire wound resistors. I would recommend getting something with at least 25W~100W ratings and thicker leads. Technically this will be more compatible with driver rating. Inductor wires no less than #16 wire. I think you will hear better resolution.
W3-871S same that W3-871? matos81 Full Range 8 20th March 2006 04:35 PM
TQWT for the TB W3-871S sergiusz Multi-Way 48 14th January 2005 12:48 PM
Tb W3-871s PeaveyBassist Multi-Way 4 14th January 2005 08:14 AM
TB w3-871s and low x-max markp Multi-Way 14 25th May 2004 11:26 PM
Copyright 1999-2017 diyAudio
