Old 24th January 2006, 02:18 PM   #221
bogoes is offline bogoes  United States
Send a message via AIM to bogoes
Westend -
I did use the Northcreek sizing guide, so just under 2L in the aperiodic section (and stuffed with polyfill), and the breathing area is VAS (~5.5L). I did not use a ScanVent, I just used a piece or 3/4" plywood with a 2.5 or 3" hole in it, a bit of fiberglass insulation (it's been a while but I think about 2.5 - 3 inches uncompressed), and a thinner (1/8") piece of wood with a matching hole to compress the fiberglass screwed into the thicker plywood on the back. The back of the thicker plywood was also rounded over just in case. This picture should help clear things up...
Concerning a planar or ribbon... I personally think the FR125 needs the help of a supertweeter. They sound good on axis but tend to lose a lot of their higher frequency once you get off axis and I listen off-axis pretty often. I used a planar with the WR125 to very good results, but I brought it in around 3.5kHz and rolled off the WR so it was really more of a 2 way than a fullrange with supertweeter. With the FR, I am running the FR full range and am employing the help of a supertweeter brought in around 10kHz to help with dispersion and give the speaker a bit of sparkle. Here's a pic of the WR with the HiVi RT1L planar...
With that said - I really don't see the point in spending the money for a ribbon or planar only to use it in a range where my hearing is not top notch. A decent dome with a smooth top end and extension out to 25kHz or so is fine with me. The one I'm playing with right now is the surface mount Dayton Neo (PE #275-030). I like it because it has almost no flange, a fairly smooth top end, and heck, they only cost $4.60 a piece. The small flange allows me to mount it as close as possible to the FR to prevent massive combing effects. And personally, I think it really sounds nice in this range - cymbals sound great. This tweeter definately bellies it's low price. I'm not quite done with this one yet so I don't have any pictures but it's using the MAPD enclosure pictured in the top pic.
Good luck.
- Chris
Old 24th January 2006, 08:56 PM   #222
Interesting post! I'm currently building my second set of FR125S fullrange speakers. I've theorized about using a tweeter crossed over above 10kHz for two reasons: 1. dispersion, 2. better high end response. However, the beauty of a fullrange speaker lies in the phase coherency. Personally, I don't think the FR125S benefits of a tweeter, the tradeoffs outweigh them.
However, i'm considering a fullranger combind with a bass driver crossed over between 200- 400 Hz using a first-order crossover. I'm surprised that this concept doesn't get attention on these forums because I think it could be truly awesome: better power handling, less distortion in bass, still great phase coherency and of course lower bass...Has anyone considered or built such a speaker?
Old 24th January 2006, 09:27 PM   #223
TerryO is offline TerryO  United States
TerryO's Avatar
It looks like what you're suggesting is a three way speaker using the FR 125, is that right? I really don't know why it wouldn't work, although the use of a WR 125 would give you probably the same results or at least approximately. You probably won't see a whole bunch on this forum as it tends toward fullrange or widerange speakers.
But rather than admonishing you for bringing up a forbidden topic on this forum, I'll give you a URL that should give you some ideas as to the feasibilty of this approach.
http://www.diycable.com/main/product...roducts_id=571
Everyone that's heard these has been quite taken by them and at the asking price they're quite a bargin. Good company to deal with as well.
In Canada, Al Wooly of Raw Acoustic has some well regarded speaker designs that utize these drivers, but I don't know what's available in kit form. Al's also a good guy to deal with.
Disclaimer: Both of these individuals I regard as friends, but I have no financial ties to their respective companies. If one or the other's product wasn't first class I wouldn't bother mentioning it
Hope this helps, good luck.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 24th January 2006, 09:36 PM   #224
http://www.diyaudio.com/forums/showt...223#post787223
Until I build my active crossovers and LT circuit they are crossed to mono at 40-200Hz using my AV amp bass management.
The woofers were necessary for getting down to 40Hz. I don't notice any obvious improvements above the crossover point, but my ears are not well trained.
Old 24th January 2006, 10:34 PM   #225
frugal-phile(tm)
planet10's Avatar
A FAST system (i still don't know what the acronym stands for). A very valid concept. A bit harder to find examples of, but there are quite a few... the Basszilla being one example. Illusus has a very nice system with a JBL woof & the FE166SER. I've a number of these in the queue... closest is an unobtainum TB 3" plus a pair of push-push coral 8".
These systems would ideally bi-amped, but should also respond to series or parallel 1st order XOs.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th January 2006, 11:59 PM   #226
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I think it depends a lot on the situation..or type of room you listen in. In nearfield listening (small computer room)..a tweeter is IMO useless. In a big room (or at least in my living room...which opens into the dining room...and kitchen...and upwards with a spiralling staircase)somehow the treble is sucked right out of the FR..(or so it sounds).....and a tweeter does the speaker a favour in that situation.
Old 25th January 2006, 08:39 AM   #227
TerryO: Actually I'm considering a 2-way system. This requires the use of a small fullranger - a 3" driver looks like a good compromise to me. The speaker kit you mentioned must be a killer system, but still way out of my financial possibilities (I'm a university student).
By the way, linearity in frequency response has a high priority on my list, so I'm looking for a fullranger that is small, linear, but with a low cutoff point (around 200 Hz or lower). Any ideas? I'm currently studying the TB 3", Omnesaudio BB 3.01 (which looks excellent on paper) and other candidates. The HiVi units seem to be of high quality but there doesn't seem to be a distributor in my vicinity (which is Europe). There's seems to be little info on the BB 3.01 of which I'd really like to know more. Anyone?
I'm sorry for being off-topic but let's look at it like we're comparing the FR125S high end response to other drivers.
Old 25th January 2006, 08:48 AM   #228
frugal-phile(tm)
planet10's Avatar
BB3.01?
My fave 3" so far is the Aura NS3. In a small sealed box it can get close to 100 Hz. Not very efficient thou.
dave
Old 25th January 2006, 12:32 PM   #229
FAST stand for Fullrange And Sub Technology.
here's a FAST project in development with the BB 3.01(german):
http://www.hifi-forum.de/index.php?a...ack=&sort=&z=1
lc
Old 25th January 2006, 02:39 PM   #230
westend is offline westend  United States
Chris,
Thanks for posting back with your results. I'm going to build a pair of the aperiodic boxes and see what they bring. If tweeters are needed I'll visit that solution after I've had a bit of listening time. My experiments with the FR125 in OB showed enough top end to keep me happy but we'll see. I plan to use the speakers for HT so the added sizzle on top might not be needed.
For the other poster looking for a 3"; as recommended by Dave, the Aurasounds are on sale here at Madisound:http://www.madisound.com/cgi-bin/ind...3176&pid=1757. You can contact them as to shipping prices. I read someone frpm Sweden was purchasing from Madisound because the price of all combined fees and taxes were cheaper than purchasing from a Euro distributor, YMMV.
FR125S playing in temp BR box, MacGyver style! Alcaid Full Range 25 17th September 2005 08:09 PM
what's better, a mid playing high, or a tweet playing low??? cody6766 Multi-Way 10 20th February 2005 09:40 PM
Still in production Zen v4 Blues Pass Labs 23 11th March 2004 09:34 AM
Page generated in 0.12852 seconds (87.61% PHP - 12.39% MySQL) with 11 queries
