Is WinISD always accurate?
Old 12th June 2005, 10:53 PM   #1
carlosfm is offline carlosfm  Portugal
Banned
Default Is WinISD always accurate?
I'm building a pair of very small, portable speakers.
The driver units are Visaton FRS 5 8ohm.
http://www.visaton.com/english/artikel/art_257_1_3.html
Frequency and impedance response:
http://www.visaton.com/english/bildg...quenzgang.html
Doesn't look bad at all...
But simulated on WinISD, I can't get much better than this.
There's always a big peak at around 300hz, no matter what volume or tuning freq. I choose.
WinISD chooses an 8.5L enclosure (?!), too big, but the peak is there.
Is WinISD fooled by the high(ish) FS of this driver - 250hz?
Or is Visaton telling us the Snow White story?
Old 12th June 2005, 11:09 PM   #2
joensd is offline joensd  Germany
the driver has got a very high Qts and that makes it impossible to get a even near flat response in a BR.
What a lot of people do with the FRS8 for example (also high Qts) is to take a sealed box (~1l) and use a series cap too flatten out the peak.
greets
jens
Old 12th June 2005, 11:13 PM   #3
grrr is offline grrr  Netherlands
Hello Carlos
I do not think you can get a flat response with a Qts 1,28 in a bas reflex enclosure. a leak closed box or open baffle may work.
Remco
Old 13th June 2005, 12:14 AM   #4
Banned
Yes, the series cap is an option, but I would loose even more bass...
I didn't think about the open baffle option, because I wanted a small speaker.
May give it a try.
What dimentions would you use for such a small driver?
Btw, after running-in for some days, these drivers sound quite good in the midband, and not bad at all in the treble, very extended.
Simulation for a 1,2L (default WinISD calc) sealed box.
The peak follows me around.
Old 13th June 2005, 12:23 AM   #5
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Wrong speakers for your intended application.
Old 13th June 2005, 12:35 AM   #6
Banned
I'm starting to figure that out...
At 8€ a piece, well...
Gonna try some open baffles, it's easy and I have the MDF...
It's a slow day, you know...
Old 13th June 2005, 06:50 AM   #7
phase_accurate is offline phase_accurate
Or use negative output resistance for your amp to reduce Qes.
Charles
Old 13th June 2005, 06:54 AM   #8
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Don't assume that an open baffle has to be large: they don't. They often are, especially with full-range drivers, but it's not an invariable rule. If you haven't looked in the theory section (concepts) here: I suggest you do before proceeding.
http://www.linkwitzlab.com/
Best
Scott
Oh -and WinISD is often quite accurate (not bad at all for freeware), but if you want better modelling software, get Martin King's MathCad worksheets.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 13th June 2005, 08:25 AM   #9
Thatīs what one would think in the first moment.
BUT a high pass at the right XO-frequency will effectively boost the bass.
Quite "trendy" at the moment in german DIY-magazines:
Sealed subwoofers with series cap(s).
greets
jens
Old 13th June 2005, 08:44 AM   #10
All I can come up with at the moment.
Plugged in some numbers in boxsim which is a nice,free and small loudspeaker sim written by a Visaton-forum-member and so includes measured responses from Visaton.
Volume is 1,2L, sealed with 120uF high-pass cap although Iīd just throw some different electrolyts at the speaker and listen.
jens
Is WinISD always accurate?Hide this!Advertise here!
would this be anywhere accurate jamikl Multi-Way 1 21st March 2009 11:12 AM
Most accurate way of matching triodes ? Fanuc Tubes / Valves 4 22nd February 2006 11:50 PM
Fast vs Accurate MaVo Multi-Way 3 25th January 2006 11:54 AM
Accurate DIY Loudspeakers atticus Multi-Way 10 21st September 2004 06:10 PM
volume POT...NOT ACCURATE! moonshow Chip Amps 4 22nd March 2004 08:58 PM
