Zaphs W3-871 notch filter? - diyAudio
Old 9th June 2005, 02:08 PM   #1
Kram is offline Kram  United Kingdom
Default Zaphs W3-871 notch filter?
Hello,
can anyone tell me if these are the same values that Zaph used in his notch filter for the Tangband W3-871?
6.8R,
3.3uF
0.7mH air core,
were there any special requirements reguarding the inductor DCR?
Thanks if anyone can help
Mark.
Old 9th June 2005, 02:17 PM   #2
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Hi Mark,
According to his article, and if you're using the first box suggested then the notch requirements are:
L1 - 0.7mH, 19 ga air core (.41 dcr)
R1 - 6.8 ohm, 10 watt non-inducitive
C1 - 8.2 mfd poly
The second/third boxes use C1 - 3.3 mfd poly
If you haven't got the article then email Zaph, I'm sure he'll email it to you, or I can email it you for that matter if Zaph has no objections.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 9th June 2005, 03:53 PM   #3
I am building the one shown in the diagram below.
It would be nice if you could send me the article, for some reason I only saved the box designes and not the crossover designs, probably assuming that Zaph wouldnt remove them from his website.
Mark
Old 9th June 2005, 04:07 PM   #4
Vikash's Avatar
That is the first design (his recommended one) which uses the following crossover:
File Type: gif audio-speaker11-xover-lowdiffraction.gif (3.2 KB, 772 views)
Old 9th June 2005, 04:47 PM   #5
Thanks Vikash
I will finally be able to complete this simple project after almost 2 years
Mark
Old 10th June 2005, 04:33 PM   #6
SQ Kid is offline SQ Kid  United States
Send a message via AIM to SQ Kid Send a message via MSN to SQ Kid Send a message via Yahoo to SQ Kid
seeing we're already on the topic, anyone have the filter diagram for zaph's taller box? thanks
Old 11th June 2005, 12:39 AM   #7
SQ Kid,
I will have it in the saved web page that Vikash emailed to me earlier, but I am away from home and my PC for the weekend so I hope you can wait that long
Mark
Old 11th June 2005, 05:53 AM   #8
i've gone almost a year without it, so a weekend is nothing
Old 11th June 2005, 03:18 PM   #9
theNoid is offline theNoid  United States
Send a message via Yahoo to theNoid
Have you tried the 871 without the SBC network? Just wondering is all...
Noidster
"Mmmmm......Beeeer"
Old 12th June 2005, 03:01 AM   #10
me?
if so, yeah, i've been running them in zaph's taller box design for about a year now. they are being powered by my pc speaker system (they took the place of the fronts in a cambridge soundworks 4.1 setup). i would not doubt that there's some sort of crossover/filter setup built into the speaker system, but they sound great the way they are now. built a 5.1 setup for my parents w/o a notch and they sound very good (also a different enclosure design). my next setup is a 6.1 B3S setup using cyburg needle enclosures for the fronts. we'll see how that goes.
Notch filter godless Multi-Way 5 22nd April 2008 10:26 AM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 10th February 2008 12:38 AM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 02:27 AM
Notch filter qguy Multi-Way 3 26th October 2006 10:26 PM
Help with notch filter nobody special Multi-Way 1 11th June 2003 03:06 PM
Copyright 1999-2017 diyAudio
