#11 |
An audition would be nice. If it will work with 1 driver that would make things a lot simpler.
I have heard great things about this drivers midrange and that it plays low. I guess I fell for moor is better adage. I guess it would make sense to see what 1 driver can do before deciding to go with 2.
#12 |
Good plan CoryLee
You will find Tim very helpful and knowledgable. I also think you will be impressed with this driver. Good luck
SCD |
#13 | |
However, the person that purchased my Rosa prototypes has agreed to let me attempt to tweak them to see if I can attack that bump. It may be that adding a small inductor to the WR125s will take care of it. |
#14 | |
#15 |
frugal-phile(tm)
The idea of using a WR for BSC with the FR is a very good idea... Using one of the 16 ohm ones on the back was also siggested as a 3 dB BSC compensation.
Chris is busy on 2 pr of bi-pole ML-TLs (one ply, one MDF). FR125s may land next week. I'm very excited about this driver. I have a couple more designs up my sleeve too. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#16 |
I would like to suggest that since this is your first project, go with the simple...single driver approach for now. From there you can see how you like them, play with some BSC maybe even as a tweak.
Once you have this relatively simple project under your belt, make a decision as to whether you need or want to ahead and get more complex with dual drivers, dipole/bipole, crossovers, etc. Shoot, from looking at your location, it seem you are right smack in the middle of WR125s/Adire land so getting an audition shouldn't be a problem for you at all I wouldn't think. Just my thoughts... Noidster
"Mmmmm......Beeeer" |
#17 | |
frugal-phile(tm)
I also drew up a 1st pass of an Onken-style BR last night (inspired by the Solo 103). Sims show that the FR125 will pop into a sealed box between about 3 & 10 litres, depending on how low a Q works for you (or what size containment is handy) dave
#18 | |
frugal-phile(tm)
Q= 0.7, net volume 9.5 litres. Q = 0.64 , net volume = 18 litres dave
| Comb spectrum generation | Elvee | Equipment & Tools | 20 | 8th July 2008 05:30 PM |
| Flat comb spectrum | Elvee | Digital Source | 0 | 1st July 2008 01:18 PM |
| Comb filtering and driver placement | angel | Multi-Way | 5 | 29th March 2004 12:04 AM |
| Comb problem? | eStatic | Multi-Way | 1 | 7th February 2004 01:25 PM |
| Hornloading, fatigue, comb filtering... | walker | Multi-Way | 1 | 20th November 2001 08:55 AM |
