FE206E enclosure - Page 6 - diyAudio
Old 12th June 2005, 09:05 AM   #51
Onur is offline Onur  Belgium
Onur's Avatar
Send a message via ICQ to Onur Send a message via MSN to Onur
Default I have uploaded the dimensions !
I have uploaded the dimensions of the Horn Enclosure to my web page.
They can be found under Fostex FE 206E link.
www.yildiz.edu.tr/~ilkorur
/Onur
Master is the master of his own Happiness
Old 20th June 2005, 02:02 PM   #52
Hi, this is my first post here!
Could someone please explain part of the Fostex recommended BLH to me? I'm looking at pieces 2,6,9 and 11 - they seem to be simple flat pieces, but looking at the side view photograph of the enclosure, they don't seem to be simply fastened to the inside of the wall. Instead they look as though they sit out a little from the wall. Perhaps I am missing something in the plans, but I'd appreciate if someone could clarify this for me.
Old 20th June 2005, 08:15 PM   #53
robertG is offline robertG  Canada
Those are dead center (when looking at the front end) and provide some reinforcement
Old 21st June 2005, 09:56 AM   #54
That makes perfect sense, thanks for the tip.
Old 27th June 2005, 08:20 PM   #55
Onur's Avatar
Default pdf is available
You can now download the drawings of the BLH (low-waf) enclosure in pdf format. By the end of this week I am planning to publish my simulation results between the recomended Fostex enclosure and Singular (without any stuffing). Also I am planning to add the BLH result among with these two. I am sure you are going to find those interesting.
Martin has asked a very nice question. I am planning to simulate that condition also. This BLH enclosure is designed to be rised from the floor level to make the speaker center at the middle height of the listening room. As he reminded, the horn mouths will have different loads when this enclosure is used as a floor-stander. I hope my simulation results are detailed enough to show us any difference. We will see.
/Onur
Old 5th August 2005, 07:48 PM   #56
TO2theD is offline TO2theD  United States
Onur,
Are your dimensions in metric (mm) or in inches?
thanks!!
Old 5th August 2005, 09:34 PM   #57
um... that was a dumb question.
but, i have another question regarding your dimensions:
the 4 pieces that make up the top and bottom of the compression chamber are unmarked in your pdf file. can you provide the length and angle measurements for these pieces?
many thanks!!!
Old 5th August 2005, 09:37 PM   #58
Onur's Avatar
Default Dimensions
They are all in metric system and the ones in pdf file are in mm.
/Onur
Old 5th August 2005, 09:41 PM   #59
Onur's Avatar
Default Missing Dimensions!
Lazy Me!
I was clearly notified about the absent dimensions by one of my friends but I am way too busy with the Ph.D. thesis these days and I forgot. Below, you can find the two pieces with their dimensions. They are indentical with the other two, top or bottom, doesn't matter.
I had the impression all of a sudden that you are in fact tying to build the design?
/Onur
Old 6th August 2005, 02:41 AM   #60
hmmm..... perhaps....
it's next - i've been playing thru the fostex plans for over 2 years now, and am ready for something BIG.
Is this TL box OK for FE206E? RWBadley Full Range 11 27th January 2011 10:42 PM
BIB for Fe206e gunnet Full Range 24 26th March 2009 03:07 PM
First FE206E enclosure beauistheman Full Range 4 14th December 2008 12:03 PM
enclosure for fe206e play from 40-300hz Fostex206 Full Range 5 17th September 2007 06:41 PM
FE206E Recommended Enclosure Skitch72 Full Range 13 24th October 2005 05:08 AM
Copyright 1999-2017 diyAudio
