Zigmahornets on their way..
Old 9th June 2005, 05:28 PM   #21
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
The quick and easy method. On reason why you couldn't, especially as the FE103E is never going to generate massive internal SPL, so vibration shouldn't be too bad. Damp the cavity with whatever you have to hand, and you should be fine.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 10th June 2005, 02:20 AM   #22
Sylver300B is offline Sylver300B  Canada
Default Re: Sloped Top Issues
Originally posted by tleonard
I assume you could eliminate the sloped top by "boxing out" that portion of the speaker and adding an internal sloped piece? Right?
Just thinking in terms of speed of construction, or WAF for someone whose wife (like mine) asked if we had to have that slope on the top!
travis
Hi Travis,
For my first project, I sure did add a few complex tricks.. And at each step, I had to figure out "how" to do it. The sloped tops are done right. As well, I added a interchangeable faceplate, so that I can try different drivers, of different sizes, without altering the cabinet afterward.. and I thought of making different face plates to match these drivers... and adding a hole at the back (covered with a plate) so that I can add a second driver at the back to make it dipole.. and I .. anyway, I'll soon put pics of it.. Let's just hope they're fun to listen to.
How do you like your own Zigmas?
Sylvain, Québec
Old 10th June 2005, 03:01 AM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Sloped Top Issues
Bipole not dipole
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th June 2005, 06:25 AM   #24
Scottmoose's Avatar
You'd need to double the effective size of these if you're going to use two drivers in biole (or any) configuration as I understand it. I could be wrong though, and it will be interesting to see what gives at any rate. Not a bad idea though -I'll have to give it a try at some point. Good luck!
Best
Scott.
Old 10th June 2005, 07:19 AM   #25
frugal-phile(tm)
planet10's Avatar
Normally it would be the case (double the cross-section. But with the variety of drivers he is trying, would be worthwhile to try.
dave
Old 10th June 2005, 09:13 AM   #26
Scottmoose's Avatar
True. I was forgetting that. The results will be interesting at any rate. I'm trying to model the Zigma in MathCad without much success at the moment -mostly because I can't for the life of me work out exactly what sort of speaker it is! Any thoughts? TL, BR?
Best
Scott
Old 10th June 2005, 10:24 AM   #27
frugal-phile(tm)
planet10's Avatar
Originally posted by Scottmoose mostly because I can't for the life of me work out exactly what sort of speaker it is! Any thoughts? TL, BR?
It is an ML-TL... best modeled in the sections worksheet -- then you can model the angle at the top & the port without any figuring.
dave
Old 10th June 2005, 11:03 AM   #28
Scottmoose's Avatar
Cheers Dave, that seemed like the best option, but I thought I'd check to make sure!
Scott
Old 10th June 2005, 11:43 AM   #29
Default theory
Well, I am just a beginer, and alas, have not much theory.. Just trying so see what makes what, and then try to explain it.
So, I made my enclosures so that I can put the Fosters in it, then try the Philips, and as well, put back the Fosters but in "bipole" configuration.
I'm almost there, just need to fnish some details, and I'm ready to go.
Sylvain, Québec
Old 10th June 2005, 01:59 PM   #30
Scottmoose's Avatar
I look forward to hearing your oppinions on the different combinations -it sounds an interesting project!
Scott
Zigmahornets on their way..Hide this!Advertise here!
Vampyr vs Metronome vs Zigmahornets, DCA 4 vs EnABled vs Fostex help! brs Full Range 9 20th July 2016 12:10 PM
questions building fe103e zigmahornets fishline Full Range 53 8th September 2009 11:56 AM
ZigmaHornets...finally!! profkirby Full Range 10 6th April 2009 02:42 PM
Copyright ©1999-2017 diyAudio
