Speaker's Fr variation with signal level - Page 4 - diyAudio
Old 5th August 2005, 04:38 PM   #31
gpapag is offline gpapag  Greece
gpapag's Avatar
All the above measurements (Vas, Q and past Fs measurements) show results that are approaching the published specs when the excitation signal is at a higher level (>400mV RMS). The lower test signals (especially below 100mV RMS) show results far away from the published data and at the same time quite sensitive to small signal variations. This, together with the fact that listening levels are produced by a signal of not less than 300mV RMS on these speakers, makes me choose the higher signal level characteristics, these of around 500mV RMS.
George
Old 5th August 2005, 05:15 PM   #32
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Originally posted by gpapag
Hi all
I took the time to do some more manual measurements to check for any change occurring to Q and Vas of the JX92S relative to excitation signal.
Results below:
Vas increases across the full span of applied signal.
How do you determine VAS? This is not directly measured.
Hear the real thing!
Old 5th August 2005, 08:43 PM   #33
gpapag's Avatar
Quote from soongsc:"How do you determine VAS? This is not directly measured."
Vas is determined using the closed box method. An unstuffed closed box with volume Vb<Vas/2 is used:
1. Measure Free air resonance freq. of driver (fs)
2. Measure In-Box resonance freq. of driver (fct). Both measurements with exactly the same signal amplitude
3. Calculate Vas=1.15[(fct/fs)^2 -1]Vb
Method is referenced in Vance Dickason “Loudspeaker Cookbook” fourth Edition pages 131-132 and David Weems “Great Sound Stereo Speaker Manual” first Edition page 208
Vas data as well as Q data and Fr data at the attachment. (Color at the columns represent: Blue=Set data, Yellow=Measured data, Green=Calculated data).
George
Speaker level to line level converters qguy Subwoofers 2 9th December 2007 03:58 PM
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
Level of the input signal Progg70 Analog Line Level 2 27th August 2005 04:51 PM
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
how to bring down line level signal to preamplifier level deji Solid State 15 15th April 2004 04:13 PM
Copyright ©1999-2017 diyAudio
