I can not stop building s*** . I have some Fostex 166 and am planning on building the BLH horn on the Fostex web site. Then I looked around in my room and realized it is the size of a postage stamp (12X12).
From other posts it seems that the room may not be suited for a horn Is it indeed to small ? Jeff |
#2 |
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#3 |
The one and only
If you have a small room and little space, the FE166E works
quite well in a .75 cu ft sealed box, stuffed, and driven by a high impedance source. If you don't want to bother loading down a current source to get the optimum impedance for the bottom end response, then you can place resistance in series with a conventional voltage source amp, say 5 to 15 ohms. Using this arrangement also makes it easy to implement a passive baffle-step correction. See the article on www.firstwatt.com
#4 |
Nelson,
Your comment helped clarify an idea in my beginner's head that it is far better to buy quality drivers than to fixate on a specific enclosure. It seems that the 166 can work in just about any enclosure, big or small, with proper tweaking and adjustment for room size. This is very encouraging. I can't wait to finish my Buschhorn project and then start something else. But I think it's clear to me now to put my money into the drivers without worrying too much about the enclosure. Doug |
#5 |
I am using the 15 litre OEM encloser now with the FE167. I used
some fill and a little duct seal to tame it a bit. I built the JE labs 2a3 for the amp , I like the sound , but the quest for audio nirvana has Conquered my sensabilitys. I thought the FE166 was designed for a BLH . Maybe I am just hyped about the woodworking challenge in building a horn. Provided a build a 21 litre sealed box using FE166 , is there much difference compared to FE167 in a 15 litre BR ? |
#6 | |
I might just encounter the same problem as our friend and his too small room. I gathered quite a lock of stock, amps, speakers and so on.. and I plan to build a humble workshop so that I can build and try amps, horns and the likes.. So, "before" starting building something, might be a good idea to as you what would be something decent for a small horn system. Ideally a two way that could be something like a 15" in a b-reflex, or a kind of Klipsch horn like speaker... and in the mean time, smaller blhorns like the Swan 101 and the likes. Oh, and about the Golden ratio? can someone remind me what it is, and give examples of what a suitable room could be?
Sylvain, Québec |
#7 | |
frugal-phile(tm)
http://mathworld.wolfram.com/GoldenRatio.html the ratio 1:phi is the golden ratio in a rectangular shape 0.618:1:1.618 The best rooms are not rectangular, but within practical limitations a significant number of the problems can be eliminated by having a roof that slopes in 2 axes (a normal vaulted ceiling would only be considered 1 direction -- but one with a "sloping" floor in the same direction as the peak (and then rotated so the floor was level) would be a practical realization of 2 axes slope). my room has a ceiling that slopes in 1 direction and goes from 7' to 17' -- it is a really good sounding room. It has a few other features that help too. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#9 | |
frugal-phile(tm)
dave
#10 | |
Have a friend who quit being a Nielson family because he got tired of them calling up and asking if thier equipment was ok as he never ever watched tv. |
| I've never used crack'ed software... | redrabbit | The Lounge | 40 | 1st November 2009 07:19 PM |
| What causes a tube to crack? | Hemingray | Tubes / Valves | 6 | 7th June 2008 08:06 PM |
| A first crack at dipoles | Roscoe Primrose | Multi-Way | 12 | 6th March 2004 08:29 PM |
| DCX2496 Password Crack ?. | mrfeedback | Digital Line Level | 0 | 5th December 2003 05:38 PM |
| Page generated in 0.11514 seconds (80.19% PHP - 19.81% MySQL) with 11 queries |
