looking for Jordan JX92 (Pre S)/ JX125 project - Page 3 - diyAudio
Old 28th August 2007, 09:42 AM   #21
Colin is offline Colin  United Kingdom
Your best bet is probably to contact Jordan direct.
Old 25th February 2008, 11:37 PM   #22
Default JX62S
Hi Earplugs, if you still have the Jordan info for the JX62
could you post it?
Old 26th February 2008, 09:42 AM   #23
I have the original spec page from the website available as a PDF. It's 250kb so if you'd like to send me a PM, I'll forward it to you.
Old 26th February 2008, 02:29 PM   #24
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Default Re: JX62S
could you post it?
http://www.spectrumaudio.de/breit/jordanJX62.html
Looks very much like Mark Audio's driver.
Hear the real thing!
Old 26th February 2008, 02:51 PM   #25
Apparently we have the technology ... albeit at low res.
PS Re-reading the thread, I realise I never did report back on the offset TL linear array. Probably because it didn't sound very good. I sold the JX53s and then TJ demonstrated how stunningly good his sounded in a wide baffle enclosure.
Old 3rd March 2008, 01:48 AM   #26
Default JX62
Thanks for the JX62 info, now I just have to find time to play with them.
Old 3rd March 2008, 03:57 PM   #27
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Hi Colin,
after I bought your JX53 I was thinking what to do with them!
I put them in a wide baffle as you suggested at the time and sounded quite good, but put them aside as I liked my other system more.
Last month I decided to finish my project as I had some JX150 sitting around. Hope tomorrow will be finished.
I am going to use the compensation circuit suggested by Jordan and a 4.5 mH coil for the bass. Hope they sound good. You can see some pictures, hope you like them.
Geroge
Old 3rd March 2008, 05:47 PM   #28
They look excellent - I hope they work well. The wide baffle approach certainly sounded good when Ted demonstrated it, giving the array a lot more weight and depth than my TLs managed. It should make crossing to a woofer a lot easier.
What enclosure are you using with the JX150 - sealed or vented?
Old 3rd March 2008, 06:12 PM   #29
vgeorge's Avatar
Sealed, about 75 litters. I' m only not sure about how low to cross the JX150. I think Ted recommends a 9 mH coil,but it sems to me very low. I will try and see. I have an 6.8 sitting around and test if I don' t like it.
Old 3rd March 2008, 06:31 PM   #30
When Ted was using a system like this he crossed over around 100 or 120Hz, letting the array run without any high pass crossover. He was also using a single JX150 per channel in a sealed enclosure. I'll be interested to read how you find the sound.
jordan jx125 beckypumps Full Range 8 29th August 2007 11:28 AM
FS single jordan jx125 pamaz Swap Meet 3 6th February 2007 03:31 PM
wtb jordan jx125 pamaz Swap Meet 6 27th April 2006 06:32 AM
FS: 2x Jordan JX125 digitoxin Swap Meet 1 10th April 2006 05:11 PM
searching for a single jordan jx125 pamaz Swap Meet 0 12th July 2005 01:43 PM
Copyright 1999-2017 diyAudio
