looking for Jordan JX92 (Pre S)/ JX125 project - Page 2 - diyAudio
Old 23rd May 2005, 03:59 PM   #11
Wow, thanks to all.
Using the information at Dave provided I even found myself back on the single driver website (last visit @ 4-5 years ago) and lo and behold someone with the almost exact same Q as me (Old JX92s).
http://fullrangedriver.com/tiki-view...ind=&forumId=1
Colin thanks for the JX125 insight (on both forums), I believe I do have the inductor value somewhere (Ah yes even posted it 5mH).
I will do a bit more research to get back up to speed then start drawing.
Again a warm thanks to all.
Old 23rd May 2005, 06:44 PM   #12
Colin is offline Colin  United Kingdom
That's a relief - for a horrible moment I thought I'd posted the same set of answers to the same person.
Good luck with the project.
Colin
Old 28th May 2005, 05:48 AM   #13
JVA is offline JVA  Canada
Colin
I just completed a pair of Jordan 125, vented enclosures,as you indicated,using 2'' vents. They could almost be used as full range , but I use them as 33 L bass units for the Jordan line array.The array had to be padded down with 11 ohm resistor and the bass unit using various coils from 1.9 to 2.7 MH ,the 125's and the 52's are a natural match,and the sound i'm getting already, makes this project well worth it.
PS. I did use the new Jordan 52's in my 5 L array enclosures ,test tone indicates they went down to 125HZ ,but sounded much better from 250HZ and up.
Joe
Old 28th May 2005, 05:11 PM   #14
Hi Joe
Glad to hear the 33L enclosures worked out. Did you use the recommended freq compensation for the JX53 array (on the Jordan site)? How low do the JX125s reach?
I'll put together my own array over the next 2 or 3 weekends but using them in an offset TL enclosure, which may help them get to 120Hz or so. I'll report back when done.
Colin
Old 30th May 2005, 04:20 AM   #15
Colin
I have the parts fore the freq. comp,just haven't used them yet. The 125's go down to about 35Hz .Also I have replaced the 2 jordan 125's in my 66L sub.[ one was bad], and used Adire's new 6.8 ,they are almost the same size.I had to change the vent size and lengthen it. I find they make a good substitute , plus they have mutch greater umph . It still is sad to see the 125's go.Good luck on your project.
Joe
Old 30th May 2005, 07:39 AM   #16
soongsc is offline soongsc  Taiwan
soongsc's Avatar
There was another thread recently trying to look for one JX125.
Hear the real thing!
Old 30th May 2005, 10:32 AM   #17
Hi Joe
Can you post more details of the Adaire driver? Ted may be interested in that one.
Colin
Old 31st May 2005, 02:29 PM   #18
pamaz is offline pamaz  Italy
Default nice to hear these news
I've built a couple of vented enclosures (around 35 liters ) and I'm going to fit these jx125 boxes with with a couple of ribbons AC g2SI.
I made some evaluations on the xover using bassbox pro and xover pro software, and i found a decent design (on paper, still not tried) crossing the jx 125 with a first order filter at 2200hz and the AC g2si at 2500-2800 Hx with a 2nd order Chebichev filter+ lpad .
Have anybody experienced something like this (or similar)?
Thanks.
Paolo
Old 31st May 2005, 08:53 PM   #19
Colin
Bob Reimer from Creative Sound Solutions will E .mail Ted on these drivers.
Joe
Old 27th August 2007, 09:13 PM   #20
bbolger is offline bbolger  United States
Default jordan watts drivers ?
Hello I have a pr of Nice jordan watts w/ bad drivers does anyomone know anything about these or where I can get some replacement drivers?
jordan jx125 beckypumps Full Range 8 29th August 2007 12:28 PM
FS single jordan jx125 pamaz Swap Meet 3 6th February 2007 04:31 PM
wtb jordan jx125 pamaz Swap Meet 6 27th April 2006 07:32 AM
FS: 2x Jordan JX125 digitoxin Swap Meet 1 10th April 2006 06:11 PM
searching for a single jordan jx125 pamaz Swap Meet 0 12th July 2005 02:43 PM
Copyright 1999-2017 diyAudio
