Unknown 5.25" Drivers -any suggestions?
Old 8th September 2006, 06:07 PM   #11
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Thank you Dave. That's easy to see now.
That link still doesn't work for me
planet10 needs your help:
Let's help Ruth and Dave
Old 10th September 2006, 09:29 AM   #12
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Likewise. The specs are pretty good; you can squeeze a lot of sound out of these cheapies. They're not Monacor quality, still less Fostex, but they're still very enjoyable, and quite smooth. If budget can't stretch further, then they're a worthy choice.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 11th September 2006, 03:52 PM   #13
offanonone is offline offanonone  United Kingdom
Has anyone made any speakers with this driver yet ?
I have done a bit of modeling in winISD standard and will probably try 8.3 lt boxes with 188mm long 130x12mm vent.
The drivers have a shiny coating on the cone, but the frames seem quite thin. Thoughts on tweaks anyone. Should i try to strengthen them with epoxy putty, or just blutack type damping on the spider and gap between frame and magnet?
Thanks for taking the time to read this.
John.
Old 11th September 2006, 04:36 PM   #14
Scottmoose's Avatar
I stuffed them into a pair of BIBs a couple of years ago -original TC version as I didn't have any T/S parameters at the time. They worked well enough. If I built them again I'd use a much shorter line though -about 95in or so. I used some trad. window putty on the spider, though they didn't ring much. Not hifi, but they're musical & good for cheapies. Their only problem is the Monacor SPH-60X, which doesn't cost much more and genuinely is hifi.
Unknown 5.25" Drivers -any suggestions?Hide this!Advertise here!
Reconing unknown drivers? xstephanx Subwoofers 5 17th April 2009 03:40 AM
Unknown 3" drivers - Can you do anything with 'em? Zeeall Full Range 16 20th May 2007 11:07 PM
4" drivers suggestions... stuman69er Multi-Way 21 21st February 2006 07:57 PM
Unknown drivers postman Multi-Way 11 31st March 2004 11:21 AM
Vifa unknown drivers Ilianh Multi-Way 2 19th September 2003 11:55 AM
