Old 5th May 2005, 08:19 PM   #11
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Re: CSS Driver Idea
Originally posted by audiobomber
Price wasn't a consideration in my case, nor was efficiency.
Even so, i'd go with WR125 + tweeter. If i wanted more efficiency, i'd be looking at Fostex.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th May 2005, 08:49 PM   #12
Timn8ter's Avatar
Default Re: Re: Poking and proding
Originally posted by planet10
Some black 1354 phase plugs is on the top of your list (1 pr backordered)... speaking of phase plugs...Tim have you had a chance to try the 207?
dave
Looks like equal opportunity prodding. I'll be playing with them tonight although I'm a little blurry eyed following last nights Moby concert.
Old 5th May 2005, 09:05 PM   #13
Default Performance of Jordan JX92S vs. CSS WR125S
Let me comment on Planet 10/Dave's reply from above:
"The 2 drivers are in the same league (until you throw price into the equation) The CSS trades going lower for a relative lack of top end. It is a fair compromise. The CSS gives up a bit of efficiency to the Jordan -- in this case a consequnce of the XBL which means less distortion. Really the Jordan is challenged to get to 80 cycles... "
These two drivers are very similar in their bass ability according to my BassBox models. The JX92S has an Xmax of 4.5 mm vs. the WR125S value of 6 mm. When I model them in the same size 7 liters vented box their 3 dB down points compute to be within 2 Hz of each other (the WR125S being lower) while the 7 liters sealed boxes 3 dB down points are within 1 Hz on the low end (the JX92S being lower). Now the JX92S has slightly more cone area so it makes up for its smaller Xmax vs. the WR125S. I would call it a dead heat on their bass ability.
The primarily differences between these drivers relate to the JX92S's capability to produce about 3 dB more output in SPL. This difference also shows up at the SPL level achievable at their rated Xmax values. At 1000 Hz and with 1 watts input the JX92S has a sensitivity of 89 dB while the WR125S runs 86 dB. With a 30 watts level signal signal at 50 Hz the vented JX92S can produce more than a 97 dB SPL level while the WR125S runs about 3 dB lower in its SPL level under the same conditions.
The JX92S trumps the CSS driver on the high end of the band (15 to 20 kHz) if you were trying to run them full range.
I have measured data on the JX92S at:
http://www.creativesound.ca/pdf/JX92SG2siDesignPak.pdf
Note that for this JX92S design the 7 liters sealed box measures at a 3 dB down point of 70 Hz and a vented box 3 dB down point is 51 Hz based upon these near field measurements.
Bottom line is that the JX92S has slightly more sensitivity and a 3 dB more SPL output level than the WR125S. It is up to the user to decide whether these sensitivity differences, any sound quality difference, and higher cost of the JX92S vs. the WR125S would be justified.
Dave, I should say that the JX92S or the WR125S can produce more than enough bass output below 80 Hz for many users. In fact, in MLTL boxes for the JX92S (and likely for the WR125S) both speakers would likely move their 3 dB down points into the 40's Hz range. Both of these drivers are rather remarkable for their size and output. Now if you wish to achieve pressure wave bass levels, you'll have to use a subwoofer with either driver.
Jim
Old 5th May 2005, 09:12 PM   #14
audiobomber's Avatar
Can someone please tell me the correct volume for a sealed bipolar WR125S? I've used two calculators and they're giving me different answers (28 vs 52L).
I entered the specs in WinISD myself, so I may have made an error.
Dan
Old 5th May 2005, 09:25 PM   #15
Timn8ter's Avatar
The answer may depend on what your goal is. Do you have a specific F3 point in mind? The volume numbers you've posted produce nearly the same F3 point however the smaller box will give you a rise approaching 100Hz before it rolls off.
Old 5th May 2005, 10:43 PM   #16
Speakerholic
Cal Weldon's Avatar
Default Re: Re: Re: Re: CSS Driver Idea
ApexJr 50 cent tweeter.
Uh Dave,
Those actually cost a whole dollar.
plus shipping
plus GST
plus exchange.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 6th May 2005, 01:39 AM   #17
I don't get it. I used this calculator http://www.mhsoft.nl/spk_calc.asp#sealed
and WinISD and specified a Q of .707 for each. How the heck do they give such a different result?
I happen to have a pair of 50L cabs with no plan, so that interests me. I'd love to stretch f3 down to 60 Hz but OTOH I'd prefer a sealed box.
Dan
Old 6th May 2005, 02:56 AM   #18
Timn8ter's Avatar
I don't know what to tell you about the on-line calculator but I can say that the 50L sealed box should perform nicely and give you extension to 80Hz which still allows enough wiggle room to roll to a sub. Should work well.
Old 6th May 2005, 04:07 AM   #19
frugal-phile(tm)
planet10's Avatar
100 litres, 50 litres, 10 litres, 0.25 cuft vented as on the spec sheet. (MacSpeakerz, factory specs)
50 & 100 are not much different Q less than 0.7
dave
Old 6th May 2005, 11:45 AM   #20
It may be sacriledge, but in our 1st crack at this puppy, we are going to waveguide load the ApexJr 50 cent tweeter. If we decide that doesn't cut it we will upgrade to the Audax gold dome version.dave
I think you should use the Hi-Vi RT1L round planar tweeter. It would be too cool to have both a tweeter and a mid-woof with copper phase plugs. ;~)
Dan
idea for a planar driver m@ Planars & Exotics 2 23rd February 2007 10:04 PM
full range driver bipole line array idea. fazman Multi-Way 2 7th January 2006 03:36 PM
Got an idea for very large subwoofer driver... eRiCdWoNg Subwoofers 4 31st May 2004 04:16 AM
IDEA: Measuring FR of a driver with room acoustics? Rarkov Everything Else 10 22nd April 2003 05:25 PM
tiny fullrange driver array idea Ignite Multi-Way 25 21st October 2002 06:01 AM
Copyright ©1999-2013 diyAudio
