Fostex 166e BLH Tweeter
Old 1st May 2005, 12:52 AM   #1
cantskienuf is offline cantskienuf  United States
Default Fostex 166e BLH Tweeter
Just finished my Fostex back-loaded horns with the FE-166E and I really like them so far. I'm thinking of experimenting with a tweeter. Of course, Fostex recommends their $144 model. Has anybody had any good luck mating this horn to some other tweeter a bit less pricey?
Old 1st May 2005, 01:13 AM   #2
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
There are probably a number of horns that would work out fine... you just need to find one that will keep up with the 166e. Fostex has a budget horn that likely will work fine. The Foster horn that comes in the Radio Shack tweeter pod is also very nice if you can find some. Even the plastic horned Fosters that RS sold would probably do the trick (i know that the less efficient alnico ones are quite sweet)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st May 2005, 01:14 AM   #3
frugal-phile(tm)
planet10's Avatar
The plastic horn is a variation on this alnico one from the 70s
dave
Old 1st May 2005, 07:08 PM   #4
uvellani is offline uvellani  United States
I use the fostex FT17H crossed over with a .68u PP cap and it gives the fe166 just the right amount of boost at the very top.
http://www.madisound.com/pdf/fostexdrivers/ft17h.pdf
Old 1st May 2005, 09:10 PM   #5
frugal-phile(tm)
planet10's Avatar
That one is commonly used, and is good... my feeling is that it and the RS pod tweeter are very closely related (it is very nice when you find the RS pods for $5/pr at a garage sale
dave
Old 1st May 2005, 11:15 PM   #6
What about the FT-100HT. Looks like a trade-off between size and sensitivity. Would I just be padding off that extra 3.5db anyway? The 166E is 94db and I haven't seen predictions for what, if any, boost is received from the BLH.
http://www.madisound.com/pdf/fostexdrivers/100ht.pdf
Old 2nd May 2005, 04:06 AM   #7
frugal-phile(tm)
planet10's Avatar
Originally posted by cantskienuf
FT-100HT
Looks like a "manta-ray" style horn. Perhaps more aimed at the low end of the pro market (that is a guess)... it is an interesting horn i hadn't previously paid any attenion too. It goes at least an octave & a half lower -- which also likely means its top-end extension is also likely an octave & a half less. Since the intended application is super-tweeter for a couple bucks more personally i'd putthe FT17 ahead in the short list.
dave
Old 12th May 2005, 02:12 AM   #8
Default Impressions
I went with the FT17 and it does add some sparkle; however, I'm not sure just yet if they're able to keep up with the drivers. I used a 0.47 uF Auricap (Fostex recommends 0.33 - 0.68) and although they are slightly used caps, they may require some additional break in. The tweets seem to need to be pointed at the listening position with the horn pointed straight ahead. At some point in the future, I think it would be worthwhile to try a more sensitive tweeter. Not to imply that this horn is anything short of the best speaker I have ever owned, and of course there may be some additional changes with additional hours. Other caps may also result in more high frequency response. Just thought I'd report my initial impression in case somebody searches FE-166E projects.
Old 12th May 2005, 02:56 AM   #9
frugal-phile(tm)
planet10's Avatar
Default Re: Impressions
nominal XO with a 0.5 uF cap is going to be 40 kHz... this is a common trick to essentially attenuate a T that is too hot. In this case you raise the Ts level by increasing the size of the cap... i'd think something as high as 1.5 uF might be called for.
dave
Old 12th May 2005, 03:59 PM   #10
zygibajt is offline zygibajt  Poland
Yes 1,5, even 2uF works good.
I myself much prefer FT 96H than FT 17. It is two times more expensive but is 4 times better and the price of about 100$ for a piece is still resonable for a good supertweeter.
Fostex 166e BLH TweeterHide this!Advertise here!
Fostex PM2 Tweeter repair kammhron Multi-Way 2 14th July 2013 04:42 PM
FS: 1 pair FE 166E full range drivers zobsky Swap Meet 0 6th August 2009 01:27 AM
Unknown tweeter, (fostex?) help? Cobra2 Multi-Way 8 16th April 2008 01:50 PM
New tweeter from fostex badman Multi-Way 11 31st May 2007 01:53 PM
Patek & Fostex 166e pwan Chip Amps 2 6th May 2007 02:48 AM
