Fostex 166e BLH Tweeter
Old 12th May 2005, 04:37 PM   #11
joensd is offline joensd  Germany
I went with the FT17 and it does add some sparkle; however, I'm not sure just yet if they're able to keep up with the drivers. I used a 0.47 uF Auricap (Fostex recommends 0.33 - 0.68) and although they are slightly used caps, they may require some additional break in. The tweets seem to need to be pointed at the listening position with the horn pointed straight ahead. At some point in the future, I think it would be worthwhile to try a more sensitive tweeter.
Donīt draw any conclusions too fast.
You might wanna try a whole bunch of different caps first and also with additional resistance.
Example:
If you like a 0.68uF-cap with your FT-17H (like me) you could try with a bigger cap but some resistance in series.
Gives a different signature than just with a cap.
jens
Old 18th May 2005, 01:34 AM   #12
cantskienuf is offline cantskienuf  United States
Default More Capacitance
Dave & Jens,
I was surprised to find just how much difference a bit more capacitance made in this case. I was digging through some of my excess stuff and bumped into a 1.0uF Bennic, so I thought I'd drop it into the circuit on one speaker and see what happened. It ended up making a pretty amazing difference. Since the other Bennic was temporarily soldered into a crossover on an array I'm also playing with, I paralleled the two 0.47uF Auricaps on the other horn. That sounded pretty good too. Now I'm convinced that the FT17 can work really well combo'd up with this horn. Thinking I'll probably play with some additional caps to find out what I like best. I've got some 1.0uF Auricaps inbound for yet another project that I may just have to install on the horns instead. Thanks for the recommendations and encouragement.
Fostex 166e BLH TweeterHide this!Advertise here!
Fostex PM2 Tweeter repair kammhron Multi-Way 2 14th July 2013 04:42 PM
FS: 1 pair FE 166E full range drivers zobsky Swap Meet 0 6th August 2009 01:27 AM
Unknown tweeter, (fostex?) help? Cobra2 Multi-Way 8 16th April 2008 01:50 PM
New tweeter from fostex badman Multi-Way 11 31st May 2007 01:53 PM
Patek & Fostex 166e pwan Chip Amps 2 6th May 2007 02:48 AM
