Old 15th May 2005, 09:24 AM   #51
pinkmouse's Avatar
Looks good!
If you fold a piece of sellotape into a diamond shape with the glue on the outside, you can run it around the VC gap and get the last few bits of stuff out.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th May 2005, 10:09 AM   #52
frugal-phile(tm)
planet10's Avatar
Originally posted by pinkmouse
Looks good!
If there is anything in there, and it doesn't work its way out, then i'll give that a try... the VC is awefully deep thou, may be real tricky.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th May 2005, 03:17 PM   #53
jeremyg is offline jeremyg  United States
Send a message via AIM to jeremyg
that last head on pic is damn sexy imho
Old 16th May 2005, 06:52 AM   #54
frugal-phile(tm)
planet10's Avatar
measured (i didn't take a baseline for the slice & dice driver)
Code:
Driver              Fs        Qms     Qes      Qts
#1 no dust cap     96.74    7.286    0.766    0.693
#1 no phase plug   96.64    7.070    0.763    0.689
#2 stock          103.29    7.553    0.902    0.806
#3 stock           98.63    7.887    0.864    0.779
#4 stock           98.94    8.187    0.870    0.786
with no reference we can only note that the modded driver has a lower Fs than the other 3 (i would expect it to rise due to lower mass), and the Qts is lower.
dave
Old 16th May 2005, 06:56 AM   #55
frugal-phile(tm)
planet10's Avatar
And the impedance curves. They pretty much fall on top of each other...
Red is #1, no cap, yellow dashed with the dust cap, the other 3 drivers in darker colors. Note the small glitch at just above 500 Hz & larger one just below 3 khz. These are absent in the stock drivers.
dave
Old 16th May 2005, 06:59 AM   #56
frugal-phile(tm)
planet10's Avatar
And a couple pictures with the phase plug that i made to fit...
Old 16th May 2005, 07:00 AM   #57
frugal-phile(tm)
planet10's Avatar
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
Phase Plug, how does it works? Antonio Multi-Way 5 17th June 2009 12:05 PM
DIY phase plug, snug fit or not? jamesdb Full Range 2 20th June 2007 08:34 PM
Phase Plug Dims ? valveitude Full Range 0 16th November 2006 03:10 PM
tangband 3" full range w/ wood phase plug? audiotang Full Range 31 5th May 2005 03:40 PM
Page generated in 0.10540 seconds (70.34% PHP - 29.66% MySQL) with 11 queries
