As the title says, I'm planing to build a pair of cheap fullrangers for really not-so-critical listening (background music, radio, TV, computer etc). This cheap fullrange driver i'm interested in is a four inch driver made by "Right", and the model "FR100-8". Of course, the expected quality for this driver is propably very low, but so is the price too. I could buy these from my work (electronics repair&service shop) at price of about 5 euros a piece. So getting a couple of these just for testing and tweaking wouldn't really hurt my wallet. I modelled the driver in MJK's "TL Offset Driver.mcd". As you can see, there are some dips and peaks in the SPL response. Because I don't have good knowledge of transmission line design, I wonder if it could be improved? Perhaps the Qts&Qes values are too high, or TL parameters I'm using are not good? The advertised specs: Qts: 0,75 Qes: 1,00 Qms: 2,966 Fs: 107 Hz Vas: 2,84 liters TL parameters: Line length: 35 inch Driver position ratio: 9 inch S0: 6 x Sd SL: 1,75 x Sd Density: 0,2 lb/ft Please post comments, feedback is welcome!
#2 |
With an Fs of 107Hz a 35" line is going to be too long. For example, the Tangband W3-871S with an advertised Fs of 110 Hz works best in ~16" line. Tuning a cabinet below the driver Fs is not beneficial unless you plan on adding heavy EQ. Also, there are some numbers missing such as port radius, length and position and it's going to be difficult getting meaningful models without the driver BL and Re measurements. Overall, I don't think this is a good candidate for a TL but as you pointed out, the price was low enough to take a chance.
#3 |
Timn8ter,
This is a very puzzling subject for me. I have modeled, using the MJK worksheets, the TB 881s to have a flat FR far below its advertised (and measured) Fs of 111Hz. What should I beware of before I construct the prototype? Or, why should I expect to use heavy EQ when my predictors demonstrate flat FR? I'm pursuing this as a personal scientific experiment, but it would be nice to add some more data to my simulations, if you have something to offer in that regard. Thanks, Dave
I have a small website for my projects. |
#4 |
To be brief I'll just quote Rick Schultz from his 08/03 AudioXpress article.
"TL myth assumes you can lower system response by building a longer pipe; pushing pipe frequency lower must extend bass performance. This myth started 65 years agoin when Voigt set "length just under one quarter of the lowest frequency at which efficient working is desired." He does not relate quarter-wave pipe frequency to driver resonance. Instead, he related it to whatever frequency "is desired." Speaker builders have assumed just building a longer pipe will extend response. In fact, building a lower frequency pipe just quiets it. Longer TLs perform much worse than shorter TLs. The lower limit for pipe frequency should equal Fs. I recommend going no lower, any longer." |
#5 |
I'm still evaluating the article, so the following comments are a little premature.
I'm still unclear what you meant by "adding heavy EQ." Were you referring to an external EQ unit, passive or active, or were you referring to stuffing as an EQ method? Oh, and I guess when we're talking about "TL," there's a current problem of referent. What I've modeled, and am about to build, is a variation of the MJK ML-TQWT. I consider that a TL in the broader sense. That's my referent. Thanks, Dave
#6 |
When I said EQ I was thinking Linkwitz Transform.
I think Martin's worksheet allows for lower driver resonance due to the air mass inside the enclosure loading the cone, however, lower Fs by mass loading changes the Q and thereby the output of the driver, so, are you really gaining anything? My personal experience is that keeping Fb equal to or above Fs is going to yield the best results. In reference to a 35" long pipe for a driver with a Fs of 107Hz.....well...
#7 | |
And...agreed. ![]() Dave
#8 |
I think you underestimate the low end performance of a TL that is sized according to the theoretical calculations.
Of course, you'll have two drivers, build both and let us know what you find out. Maybe you'll find something new. :)ensen.
Those who claim to be making history are often the same ones repeating it. |
#9 | ||
Greets!
What are all the specs you are using? Do you know Re, Le, Sd? The IB response (dashed line) is totally whacked for the specs you published so your sim is useless. Quote:
Sd = 45.6064 cm^2 (assumes 3" effective dia.) Re = 8 ohms Le = 0.6 mH BL = 3.512 N/A pipe Vb = ~0.71 ft^3 per T/S I get: L = 25.25" eta = 9.42" SO = 90.48"^2 (~12.8*Sd) SL = 6.05"^2 (~0.856*Sd) density = 0.25 Quote:
WRT gain, pipe Vb must increase with decreasing Fp (length). When it comes to loading high Q drivers and/or loading a driver below Fs, Vb (air mass) is the acoustic lever required to help a 'weak' driver load the terminus. Voigt understood this. If you don't provide it then RS's statement is at least semi-correct. It's all a matter of what the performance goals/acceptable trade-offs are.GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#10 |
Hey GM,
Just a practical question: how do you build enclosures which taper from 90.48" sq. to 6.05" sq? Am I really that far behind in my woodworking skills? Please tell me that you round up or down... Dave
| Need advice for next project - should I go fullrange or multi-way? | Bubba Zanetti | Multi-Way | 14 | 16th February 2009 07:19 PM |
| Cheap Philips fullrange on OB | Calamaro | Full Range | 10 | 16th October 2008 03:50 PM |
| Cheap 6 1/2 inch fullrange drivers | dpuopolo | Full Range | 4 | 4th December 2007 07:12 PM |
| My first fullrange project - FR125s | Foxx510 | Full Range | 23 | 8th August 2007 11:03 PM |
| need help : fullrange speakers project | punk | Multi-Way | 24 | 28th February 2003 08:47 PM |
