Large backloaded Fostex horn??? Large backloaded Fostex horn??? - diyAudio
Old 20th April 2005, 12:28 PM   #1
Circlomanen is offline Circlomanen  Sweden
Default Large backloaded Fostex horn???
Anyone know of any realy large backloaded horn design for Fostex FE206 ???
We live in a horizontal world, why use vertical topologies???
Old 20th April 2005, 02:17 PM   #2
paba is offline paba  Canada
I googled onto this site, these are large horns, the examples are with lowther but I suspect that with some work Fostex could be used as well.
click on Double Horn or Maximum Horn
http://www.maxresearch.com/pagina%20...Produzione.htm
Old 20th April 2005, 03:28 PM   #3
Thanks for the link.
I really like the MAXIMUM horn!!! Its awsome! Should be able to play some bass!
Imagine a 15 inch woofer in there.
Old 20th April 2005, 05:59 PM   #4
Here is another large horn
www.passdiy.com/pdf/KleinHorn.pdf
www.passdiy.com/pdf/KleinHorn2.pdf
with the jordan driver.
have fun
Paba
Old 22nd April 2005, 07:12 AM   #5
AndrewT is online now AndrewT  Scotland
Hi circlomanen,
Maximum WOW, the folding inside that central section must be demanding.
When you have some details share them with us.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd April 2005, 11:04 PM   #6
Olle Bard is offline Olle Bard  Sweden
Send a message via MSN to Olle Bard
The bigger the better i presume Circlo
Why not rescale The Imperial... make it bigger!
I like turning knobs clockwise
Old 23rd April 2005, 06:33 AM   #7
JAPP!!! Ju större ju bättre!!! (The bigger the better!!!)
The Imperial upsized will not fit a pair of FOSTEX FE206. But would be very fun with a pair of Cervin Vega Stroker 18 in each Imperial.
Make them 7 x 5 x 4 feet!!!
Old 23rd April 2005, 04:49 PM   #8
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
How about a scaled up Imperial with a Harley 24" like this one? Steve even includes the scaling.
http://www.steevee.com/jensen/jensen.htm
Everyone has a photographic memory. It's just that most are out of film.
Old 23rd April 2005, 05:14 PM   #9
GM is offline GM  United States
GM's Avatar
Default Re: Large backloaded Fostex horn???
Greets!
The 'jack o' trades' Jensen Imperial horn looks good in a sim as is if corner loaded or with ~3 ohms series R if well out into the room.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd April 2005, 07:24 PM   #10
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I'm running the Fostex FE206E's in the Kleinhorns at this very
moment. A little EQ on the top and bottom and they work fine.
Large backloaded Fostex horn???Hide this!Advertise here!
Backloaded Horn for Fostex FE 83 becki200 Full Range 34 4th January 2011 12:37 AM
fostex fe107e backloaded horn hendram Full Range 3 21st July 2009 02:10 AM
Backloaded horn with Fostex FE206E Arie Full Range 1 9th February 2008 01:28 PM
FS: Fostex FE206E (Decware modified) backloaded horn with Karlson Slot $299 bbaker6212 Swap Meet 4 24th September 2007 04:34 PM
Recommende Fostex backloaded horn project rho Full Range 2 6th May 2007 07:38 AM
Copyright ©1999-2017 diyAudio
