Old 13th April 2005, 06:29 AM   #1
frugal-phile(tm)
planet10's Avatar
Default $7 open baffles...
Chris, Scott & I got together last Saturday with the prime purpose of cleaning up the "recycle facility" a bit, listen & tweak the FE127 prototypes, and to make an approximation of an RH84.
During clean-up Chris wanted to toss a set of unual shaped "wings" i had collected off the side of the road, to which i said i would use them for open baffles, then he asked when would i ever get at it, so i grabbed a set of vintage foster 6" with whizzer cones and tasked Scott to build them... which he did on the back of his truck.
I got them upstairs into the main system today (had to sell the drivers in what i was listening too after Scott took the bi-pole 40-1197 ML-Voigts away). These are quite respectable with a ton of room for tweakage -- including removing extraneous hardware that came with the baffles, actually cleaning them, making a better leg, and of course tweaking the driver and how it is mounted. I threw the BSC circuit from my blue & yellow Frugal-phile(tm) specials on them for a bit of midband suppression.
Looking at the baffles, i'm guessing they were actually partitions for some irregular shaped conveyance, perhaps an airplane or a mobile living facility. An atractive shape never-the-less.
I've a ton of the drivers i chose -- i score every pair of the distinctive Lloyds boxes these come out of (about 1 in 4 yeilds a pr that are an alnico variation). I typically pair $7/pr for these (5.7 USD/4.4 Euro). All other bits are salvage that was laying around and the baffles were on the side of the road (i got a couple loads as the guy was cleaning out a workshop).
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th April 2005, 06:30 AM   #2
frugal-phile(tm)
planet10's Avatar
oops... the pictures... in the system
Old 13th April 2005, 06:31 AM   #3
frugal-phile(tm)
planet10's Avatar
zoom in on a single speaker
Old 13th April 2005, 06:32 AM   #4
frugal-phile(tm)
planet10's Avatar
and a close up of the driver (i have to scallop out the back of the hole (i'll also rebate the front to flush mount them).
Old 13th April 2005, 06:18 PM   #5
chrisb is offline chrisb  Canada
Default power hunger
how do the OB's like the extra horsepower of the Jolida?
Old 13th April 2005, 06:25 PM   #6
SY's Avatar
Classy piece of scrounging there! What does the driver's impedance curve look like?
BTW, it's a pleasure to see someone's living room that looks like mine.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 13th April 2005, 07:02 PM   #7
frugal-phile(tm)
planet10's Avatar
Default Re: power hunger
Officially the Jolida has less power than the Onkyo, but sounds WAY better -- a good thing since a single output tube costs more than the whole receiver
dave
Old 13th April 2005, 07:04 PM   #8
frugal-phile(tm)
planet10's Avatar
attached
good thing it was cleaned up... no static fancy-pancy showplace this house
dave
Old 13th April 2005, 08:32 PM   #9
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Id like to get my speakers out there and test them now. Turn them up let them play. Then after take each driver out and mesure them : O )
Old 14th April 2005, 12:34 PM   #10
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I've just flogged through this thread and haven't seen any mention of how the baffles sound!
(Nice cat, though.)
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Open Baffles at RMAF-07 Pano Multi-Way 27 18th August 2008 01:08 AM
WMTMW Open Baffles Magnetar Multi-Way 47 14th November 2007 02:20 AM
New open baffles hurdy_gurdyman Multi-Way 3 26th September 2007 02:22 PM
Open Baffles :- ) brianon Multi-Way 17 3rd February 2004 08:13 PM
Open baffles? dc Multi-Way 5 28th December 2001 02:10 AM
Page generated in 0.13290 seconds (78.28% PHP - 21.72% MySQL) with 11 queries
