small MLTL is hardwood OK? - Page 3 - diyAudio
Old 28th March 2005, 08:35 AM   #21
Scottmoose's Avatar
Originally posted by TC
John, the above demonstrates sensitivity to the material on a craftsmans level. Patience is where it all starts and usually ends. I'd say you are doing great.
TC
Terry, you're now making me wish it was possible to get some decent wood near where I live in the UK, out of practice with it though I am!
MDF, lousy cheap ply and very narrow, very young, very rough, and mositure-filled pine planks still oozing resin (9"x.75"xwhatever") is about the limit near here, and worse, nobody seems in the least bit bothered; an apathy typical for this area sadly. The aforementioned pine was what my friend Eric built his pipes from -I fear the worst. 'Bit odd really considering a goodly proportion of all the wood shipped into the UK transits Hull (which I live in a suburb of), but there you have it. One major reason I stick with MDF for my speaker cabinets!
While we're on the subject, can any of our UK members reccommend a decent timber supplier? The North Yorkshire supplier I used to buy from (this was before I became interested in designing and building speakers a couple of years ago) went out of business a while back, and I'm not a fan of mail-order without hearing reccomendations?
Scott
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 28th March 2005, 01:45 PM   #22
TC is offline TC  United States
I'd take a peek inside some chippy's (carpenter) shops. I bet there must be whats known as -secondary hardwood-. Wood used for drawers frames etc.. that's generally chaeper and in abundance. Poplar, Damar, Phillipine mahogany. I bet the polars and birch, "whitewoods" must be available. Might not find them at lumberyards but there must be a commercial fabrication shop that would have better information.
Best.
TC
Old 28th March 2005, 05:13 PM   #23
Scottmoose's Avatar
Best.
TC
Thanks for the advice -it's much appreciated & will do just that! (I must be having a slow day or something...)
Cheers for now
Scott
Old 28th March 2005, 07:59 PM   #24
Timn8ter's Avatar
Seems like a good plan to me. I'm interested in what your results are. Not necessarily with the wood but the design in general and how it compares to what has been discussed in this thread.
Old 28th March 2005, 08:18 PM   #25
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
I should have known that this was the right place to start the thread.
I really want to do this as a one day project and waiting of glue to dry will waste a lot of time. Are any of these newer glues really as good or better and wood glue?
Everyone has a photographic memory. It's just that most are out of film.
Old 28th March 2005, 08:27 PM   #26
Scottmoose's Avatar
I don't pretend to be an expert, but I'd personally stick with a decent wood-glue myself and put up with the delay. Maybe I'm just old fashioned (well, I am a historian, what do you expect ), but even though I'm only 26, I've still seen too many so-called miricle products emerge and vanish just as quickly into well-earned obscurity. If you're desperate to try something new, I've had some quite decent results with No More Nails, but I still prefer the old way. It doesn't dry that much quicker either.
If you're using an attractive hardwood, don't rush it! Just a thought.
Old 28th March 2005, 08:32 PM   #27
Timn8ter's Avatar
Yeah, stick with the wood glue. The new poly glues are great if you have an irregular cut because it expands but it takes a long time to set up and harden. Real messy too. I prefer Tite Bond.
Old 28th March 2005, 09:00 PM   #28
OK, I always use wood glue anyway. This will be strickly glue, so how long do I have to wait before taking the router and sander to it? The bottle says 30 minutes of pressure, but nothing about how long for a full bond. I usually wait a couple of hours to do anything, but this is the first time to attempt a quick job without the security of screws.
Old 28th March 2005, 09:16 PM   #29
Timn8ter's Avatar
I try not to stress joints for 24 hours. I suppose it may depend on how "stress" is defined.
Old 28th March 2005, 10:07 PM   #30
The vibration of routing and sanding would seem to me like a bad thing for a joint that isn't fully cured. I've always questioned why they don't put it on the bottle like just about any other glue. Out of curiosity I've tested a bond after 30 minutes of pressure and it definitely takes longer than that.
Small MLTL for Mark Audio Alpair 6 Drivers Jim Griffin Full Range 31 27th June 2016 08:21 PM
Owl Hardwood in USA will cut your mdf DaveThreshold Multi-Way 0 17th July 2006 10:24 AM
hardwood for cabinet audiothings Multi-Way 3 17th September 2005 12:02 PM
FE127E in small hardwood MLTL johninCR Multi-Way 6 28th March 2005 07:19 PM
What to use on Hardwood floors? m1abrams Multi-Way 2 31st July 2004 01:47 PM
Copyright 1999-2017 diyAudio
