MLTL 206 Filter components
Old 21st March 2005, 03:11 PM   #1
zotar is offline zotar  United States
Default MLTL 206 Filter components
Trying to fine tune my MK MLTL Fostex 206, I now using Madisound Sledgehammer 3.0mH inductor, would the perfect lay type or Goertz type be an improvement? Using a Multicap 4.0uf film and aluminum cap, any suggestions? Tried a 3.0 Hovland and Auricap. A 4.5 ohm parallel resistor seems to give me the best balance. Thanks in advance.
Old 21st March 2005, 07:44 PM   #2
zygibajt is offline zygibajt  Poland
I'm using FE 204 which is the older brother of FE 206, and is quite similar in parameters.
I got best results with 10ohm resistor, 4mH coil and 2uF cap.
Bartek
Old 24th March 2005, 06:38 PM   #3
Toropkin is offline Toropkin  Russian Federation
I got best results with 10ohm resistor, 1mH coil and 2,42uF cap
in parallel.
Driver - FE-206
Old 25th March 2005, 09:58 AM   #4
weidok is offline weidok  Netherlands
weidok's Avatar
Default Re: MLTL 206 Filter components
I am using 1,8 mH and 8 ohm in a ML TL wih the FE 167 E
no caps at all !!!!
Do you have pictures and drawings of the enclosure
There is NoBox like NoBox
Old 25th March 2005, 10:29 AM   #5
Default Re: Re: MLTL 206 Filter components
no caps at all !!!!
Please:
http://www.metaleater.narod.ru/ls2061.jpg
http://www.metaleater.narod.ru/ls2060.jpg
http://www.metaleater.narod.ru/ls206.jpg
- my system
Original blueprinting:
http://www.sloejd-kbh.dk/tema/speake...iko/jeriko.htm
Old 25th March 2005, 01:55 PM   #6
Default Fostex 206E
The cabinet plans can be found at Martin King's MLTL website. I am surprised at the difference in filter network components being used by the readers. I started with the recommended filter by M.King and modified it slightly. Are you guys using the same cabinet parameters?
MLTL 206 Filter componentsHide this!Advertise here!
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 10th February 2008 12:38 AM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 02:12 PM
Filter Components k1jroth Parts 0 18th November 2004 01:58 PM
Allpass filter design using passive components Zodiac Digital Source 2 20th September 2003 06:13 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 11:17 AM
