I think more of a simple math question but I can't seem to get it straight. I am working on the recommended FE126E enclosure which is a hybrid back loaded horn / bass reflex design. Anyway I want to convert the port to english units from millimeters (don't have an 30 mm pipe!)
I know the port is 30mm diameter and 115 mm in length and Fb is 55 Hz Due to the design I don't know what to include to calculate the enclosure volume. What would the length need to be to use 1.5" port? Thanks in advance, Tim Here is a link to the design: http://www.madisound.com/pdf/fostexcabs/fe126e_encl.pdf |
#2 |
If you use the ratio 1"=25.4mm that's close enough for most applications. I've started a thread on the enclosure you want to build here, where I think a few of us are considering it:
Fostex FE126E reference design opinions Feel free to join us and let us know how you get on. Good luck, Steve |
#3 |
Thanks for the reply and I will keep an eye on that thread to see what others are trying out.
I don't have any issue converting the mm to inches but the port comes out to 1.18" in diameter and 4.5" long. I don't have any material that is that diameter and wondered how to calculate the new length if I change the diameter to 1.5".. Maybe I'm not making sense... (wouldn't be the first time) Tim |
#4 |
Greets!
Ron E's take on scaling vents: .........L1/L2 = A1/A2, where L1, A1 are the original length and area, and L2,A2 are the new length and area... rearranging again, and Realizing that area is proportional to diameter squared: L2 = L1*(D2^2/D1^2), where D2 is new diameter and D1 is the original diameter. FWIW, *in sims* using MJK's WSs I found that accounting for the end correction difference was more accurate, probably audibly so if a big change in diameter was made, but as always YMMV: L2 = L1*(D2^2/D1^2)+(D2-D1)^2 GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
Thanks! that is exactly what I needed!
Tim |
| fe126e 2 way enclosure with woofer | lionking7 | Full Range | 21 | 26th July 2008 03:25 AM |
| FE126E in a 23 litre enclosure | audiophile36 | Full Range | 14 | 23rd September 2006 10:49 AM |
| Sub enclosure Question (s) | Safe_Cracker | Car Audio | 6 | 14th January 2006 04:02 AM |
| TL Enclosure question | CH2 | Multi-Way | 0 | 23rd April 2004 03:21 AM |
| Enclosure question | kderedwolf | Parts | 1 | 9th October 2003 05:54 AM |
| Page generated in 0.08124 seconds (70.92% PHP - 29.08% MySQL) with 10 queries |
